KOER Test Help - Ford Truck Enthusiasts Forums
KOER Test Help
Old 08-29-2009, 12:20 AM
circllb circllb is offline
circllb is starting off with a positive reputation.
KOER Test Help
I have a 1988 f350 460 motor. I try to run the KOER Test but the box states Unable to read data from vehicle. The key is on and the box is plugged in. Ran KOEO test and got code 18. I need some help if any
Thanks
Old 08-29-2009, 07:47 AM
subford's Avatar
subford subford is offline
subford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud of
There is not a code 18 for KOEO.
If it was a code 18 in CM then it means you lost the IDM information from the Ignition system to the computer.
If it was from CM post back and we will tell you what to test for that.
And what is the box?
Does this box have a name and model number?
I would look very close at the computer and its plug.
Also check out the Ignition system wiring and resistor.
Old 08-29-2009, 06:53 PM
On the Code Scanner 2500, there are 2 test. KOER and KOEO. When trying to run KOER get Unable to read date from vehicle. Had a new computer put in back in Fedruary.
Old 09-01-2009, 11:38 AM
It was from CM, 18 Loss of Ignition diagrostic monitor signal to the control module/ spark output grounded. code 33 EGR valve closed/ erratic or has insufficient flow.
Old 09-01-2009, 11:56 AM
subford's Avatar
The 33 is more than likely a bad vacuum line from the EGR valve to EVR solenoid or not vacuum to the EVR solenoid. Test with a hand vacuum pump and ohm/volt meter.
Continuous Memory Code 18 indicates a loss of IDM input to the processor.
Possible causes:
-- Open harness.
-- Shorted harness.
-- TFI module
-- Processor.
Key off.
Disconnect processor 60 pin connector. Inspect for damaged or pushed out pins, corrosion, loose wires, etc. Service as necessary.
Leave processor disconnected.
Disconnect E-core ignition coil and TFI module.
Measure resistance between Pin 4 at the of the Computer plug and IDM circuit at TFI vehicle harness connector.
Is resistance between 20,000 and 24,000 ohms?
If No:
SERVICE open circuit. RECONNECT processor. CLEAR Continuous Memory Codes. RECONNECT all components.
If Yes:
Key off.
Processor and TFI module disconnected.
Measure voltage between Pin 4 of the Computer plug and battery negative post.
Key on, engine off.
Measure voltage between Pin 4 of the Computer plug Pins 40 and 60 of the Computer plug.
Is any voltage reading greater than 10.5 volts?
Yes
SERVICE short circuit. RECONNECT all components.
If No
Then post back and we will go deeper.
KOER test help giorgio.fo Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 0 09-19-2014 09:34 PM
AE Help - KOER test procedure caere 6.0L Power Stroke Diesel 9 11-30-2010 06:36 PM
ODB1 Code 53 on KOEO and KOER texasyakfisher71 1987 - 1996 F150 & Larger F-Series Trucks 3 08-03-2010 02:30 PM
koeo and koer code tests goodwrench 1987 - 1996 F150 & Larger F-Series Trucks 4 03-13-2009 11:23 AM
KOER code 13 problems 91ford_ranger 2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6 2 07-30-2004 12:42 AM
Tags
eradic, erratic, f150, f350, ford, idm, input, koer, lost, module, pricing, procedure, processor, test, tfi
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
