running boards
08-28-2009, 09:18 PM
on
running boards
been trying to find some for my '54 panel (good straight one's), has anyone tried the fiberglass boards from fairlane company. i'm not a small guy and i use them to get in, so they need to be strong.
thanks for your input
08-29-2009, 06:02 AM
I can't find the info but I know someone makes steel panel truck running boards. They are the smoothie type without ribs. If I find more info I will post it for you.
brian...
08-29-2009, 09:15 AM
on
I got some back in 1989 for my 55 I used them also they held up great I just got some steel ones a couple years ago just because there still isn't anything wrong with the glass ones. I never painted them just clean them up.
08-29-2009, 10:49 AM
running board sources
Sacramento Vintage Ford (where I've spent way too much $$ ) has them for your model ribbed like original (stock style ) $400.00 /pair Smooth $400.00 /pair
Hot Rods $310.00 for fiberglass
Try Smoothie Fabrications Iron Station , N.C.877- 218- 1937
Reason: wrong info
08-29-2009, 01:18 PM
more panel running board info .
Smoothie fabrication $400.00 also
08-31-2009, 09:24 PM
on
i'll look into the vintage ford one's. i should have put i wanted stock looking (ribs) ones, mine have plates welded on top under the step cover and i was thinking either cutting and welding p/u sections in mine or find better ones.
08-31-2009, 11:27 PM
on
i have a extra set that came with my 50 merc m-68.have a look in my photo album under running boards,see if they will work for you.if they will we can work something out im sure.
ChuckRob
03-26-2013 12:22 PM
dalesatter
1997-2006 Expedition & Navigator
06-12-2010 12:34 AM
z1121jack
12-31-2008 09:00 PM
blahboo
05-30-2006 08:59 AM
kiosk
12-28-2004 06:48 AM
