Transmission Filter - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Transmission Filter
Old 08-28-2009, 06:22 PM
rocky1074's Avatar
rocky1074 rocky1074 is offline
rocky1074 is gaining momentum as a positive member of FTE.rocky1074 is gaining momentum as a positive member of FTE.
Transmission Filter
I have a Ford F-350 Super Duty Pickup V8 6.0 Fuel Injected Turbo Diesel . I am planning to change the fluid and filter. I know it has a FT-145 External Filter. Is there Also a in pan filter????. I don't want to drop the pan if there is no filter there, being it has a drain plug. Thanks, mrrocky@wildblue.net
Old 08-28-2009, 06:24 PM
bpounds's Avatar
bpounds bpounds is offline
2 bit Californian
bpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputation
No need to drop the pan. The internal filter is only a screen.
Old 08-28-2009, 06:36 PM
rocky1074's Avatar
Ok Thanks for the info...Will make the job easy. I really didn't want to drop the pan..
Old 08-28-2009, 06:40 PM
bpounds's Avatar
2 bit Californian
No problem. Just be aware that you will only drain about 7-8 quarts, and the system holds 17, so what you are doing will be changing about 1/2 of the fluid. The TC does not have a drain plug. To do a proper flush requires a heated machine at the dealership.
I assume you already know that you MUST use Motorcraft SP fluid - there are no suitable substitutes.
Old 08-28-2009, 06:45 PM
rocky1074's Avatar
Yes I know. I have the Motorcraft Mercon SP fluid on hand.. Thanks again for your help!!
Old 08-28-2009, 07:59 PM
EXv10 EXv10 is offline
EXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputation
Quote:
A rag will take that off.
Old 08-28-2009, 09:14 PM
rocky1074's Avatar
I didn't mean I had fluid on my hands. I had the fluid in stock!!!!!! TO USE!!!!!
Old 06-29-2010, 05:06 PM
satwood's Avatar
satwood satwood is offline
satwood is starting off with a positive reputation.
External Trans Filter Removal
Guys,
This will be my first transmission fluid change since I bought my 2003 F350 last fall. From searching dealer records I can't tell if the fluid was ever changed before. It's got just over 50K original miles. I tried last weekend to loosen the external filter housing and all I managed to do is bend the mounting bracket with the bar and socket. It seems very flimsy. What's the trick for getting that loose?
Also, to confirm I'm going to do this right:
1) I do not need to remove the pan, just drain from the plug. It's the 5 speed with tow/haul on the column
2) Change the external filter and install the new motorcraft filter I bought (white roll of cloth-like thing)
3) Install 7 - 9 quarts of Mercon SP or LV. I need to check but I think the dealer sold me LV. I will make sure it is not V.
4) Repeat in about 10K miles because I'm way behind the 30K change interval.
Anything else I should know to do this right?
Thanks much
Steve
Old 06-29-2010, 05:13 PM
bpounds's Avatar
2 bit Californian
Quote:
Originally Posted by satwood View Post
Guys,
Thanks much
Steve
A quick shot with an impact wrench is the best way to loosen the filter housing. If you don't have that, then a quick smack with a BFH on your wrench might work.
No need to drop the pan. There is nothing but a screen inside.
You have a Torqshift 5R110.
SP has been superceded by LV, so that's probably all the dealer can get you. Just make sure it is LV and not V, and you should be good.
I would recommend you forget all that and have the dealer do a complete hot flush. But if you insist, the above is about all you can do in the driveway. Repeat every 10 or 15k sounds reasonable. Unless the truck has hauled heavy a lot, I would not be too concerned about being late on the service. These are usually a very stout tran's.
Old 06-29-2010, 07:18 PM
TennesseeMustangPerf's Avatar
TennesseeMustangPerf TennesseeMustangPerf is offline
TennesseeMustangPerf has a good reputation on FTE.TennesseeMustangPerf has a good reputation on FTE.
Actually, I had recently had to drop the pan due to a crappy tranny sending unit snapping off, and replaced the filter as well. There is a filter that presses into place that can only be removed by dropping the pan down.
Old 06-30-2010, 08:01 PM
5.4f250sd's Avatar
5.4f250sd 5.4f250sd is offline
5.4f250sd is starting off with a positive reputation.
I just got done doing this and I replace both the inside screen and the toilet paper. My screen did have some larger particals on it but I am a little ****. My truck also came from 1500 miles from home and I knew nothing about the trucks prier history and it has 100k on the ticker. Good luck bud. Nothing to it.
Old 07-01-2010, 05:34 AM
Furian's Avatar
Furian Furian is offline
You Keep What You Kill
Furian has a great reputation on FTE.Furian has a great reputation on FTE.Furian has a great reputation on FTE.Furian has a great reputation on FTE.
The 2008-2010 Super Duties have a smaller partical sized internal filter that you can use for better cleaning of the ATF. However, you will need to replace the transmission pan because the newer filter is wider than the original internal filter.
Part# 8c3z7a098d - $40.86 each from Ed's.
1985 F150 Inline 4 Manual 4x4 - SMOG HELP PLEASE Brian Goodman 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 19 06-01-2016 12:23 PM
New Trans Filter or Not? acstokes 1999 to 2016 Super Duty 4 09-29-2014 01:47 PM
Fumoto HFCM drain maybe??? phantomphixer 6.0L Power Stroke Diesel 6 11-13-2012 06:04 AM
What color is Ford Gold coolant? Serious Question Tylus 6.0L Power Stroke Diesel 25 10-11-2011 05:18 PM
1996-2004 Ford Truck Transmission Pan W/Drain plug..NEW PRODUCT 1ATony Vendor Specials, Discounts, Product Announcements & Group Buys 2 06-15-2009 02:01 PM
Tags
2006, 60, 8c3z7a098d, changing, f250, filter, filters, ford, housing, motorcraft, superduty, trans, transmission, transmisson, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
