Go Back   Ford Truck Enthusiasts Forums > Misc. > Fuel Injection, Carburetion and Fuel System
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #16 (permalink)
Old 03-06-2009, 11:42 PM
bronzeback bronzeback is offline
bronzeback is starting off with a positive reputation.
I have a question TorqueKing. When taking the readings and making the adjustments is the vehicle in park or drive and air cleaner on or off? Sorry if it's a stupid question.
Thanks
  #17 (permalink)
Old 06-23-2009, 12:14 PM
0280adam 0280adam is offline
0280adam is starting off with a positive reputation.
Adjusting an Edelbrock Carb.
I have a similar issue like Skipper with my edelbrock carb. My carb is exactly the same as Skippers and I do not know how to adjust the carb either. The car really heisitates when the gas is pressed down-sometimes at take off an sometimes when you need to speed up after you are moving. The car is really hard to start after it is shut off. I seems like it is loading up. I see that the adjustments that TorqueKing recommends adjusts the idle circuit but not acceleration circuit. I have no idea how to adjust the primary metering rods. If your out there TorqueKing I could really use your help. Thanks in advance.
  #18 (permalink)
Old 06-23-2009, 12:37 PM
gfw1985's Avatar
gfw1985 gfw1985 is offline
gfw1985 is starting off with a positive reputation.
Quote:
You adjust by changing the springs and/or the rods. The Edelbrock kit is #1487 for the 1406. Complete set of springs, rods, and jets. It's really simple. My squirters were partially clogged giving me most of my problems. While I had it down, I went up to 1 rich on the rods and next to heaviest springs. That and a little choke adjustment and no hesitation off idle or full throttle. A lot more responsive. This may help till TorqueKing checks in.
  #19 (permalink)
Old 06-25-2009, 11:35 AM
I hate adjusting carbs.
  #20 (permalink)
Old 07-25-2009, 10:46 PM
BaronVonAutomatc BaronVonAutomatc is offline
BaronVonAutomatc is starting off with a positive reputation.
Well, I'm late to the party on this, but I just went through a similar problem. My carb was too lean at idle and too rich at part and full throttle acceleration.
Get the idle mixture dialed in first. Turn the mixture screws on the front all the way in, then back them out two turns. You'll really need a vacuum gauge to do it right. Hook up the gauge and let the truck come up to temp. Turn the right screw in 1/4 turn and check the vacuum reading - if it goes up, then try another 1/4 turn. If it goes down, back it out 1/2 turn. Keep going 1/4 turn (in whatever direction) at a time until you get the highest vacuum reading. Idle RPM should also go up. Adjust the idle and do the same thing with the left screw.
Drive the truck and see if it runs better.
Then try adjusting the accelerator pump - on the front of the carb next to the throttle linkage. Move the linkage to the bottom hole (stock is the middle hole, bottom hole is a smaller pump shot). Drive the truck again and see if it's better.
If it's better but still bogs try dialing in a couple of degrees more timing and reset the idle speed/mixture. Drive it again. If you've still got a bit of bog, consult the Edelbrock carb manual for the correct rods to lean it out a bit more. Rod changes take ~5 minutes and don't require removing the carb.
__________________
1986 Bronco w/300 I6 & ZF 5-Speed
1982 F250 4x4 w/302 & C6
Tags
1407 , 300 , 86 , adj , adjust , carb , carborators , carburetor , cover , edelbrock , ford , idle , rich , runs , screws , setting
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
