300-6 Heads?
300-6 Heads?
I have an 85 F150 2wd with the 300 and a T-18. I'm pretty sure the valve guides are toast with the way it burns oil and fouls the plugs...blue cloud at start up and when revved after idling, but not driving down the road. Anyway, I've looked up how to replace valve guides without removing the head and I do not have the air compressor to hold the valves in place while I remove the spring so I would have to pull the head to do them. I am open to any ideas on how to hold the valve in place using cheaper means as well.
So I started thinking, if I have to pull the head anyway, why not get it refreshed...which lead me to wonder if there are different castings of this head that might be better than my 85. Are there any pre-smog heads? Where could I find a good one and would I realize any power gains? Not trying to make a dragster, just looking for a little more oomph.
Thanks!
Thanks!
Thanks!
Thanks!
I would do a compression check first, before I did anything. follow the commpression check with a leak down test, that way you know what condition your rings are in, before you spend money on head work, only to have to tear it all down again for a rebuild. one way to see how the rings are preforming, is to go down a large hill without touching the gas, when you get to the bottom, floor it, and watch behind you. if you fog the whole block with blue smoke, you need a whole rebuild, your rings are shot. if it only smokes on start up, you need valve seals.
anything that will allow the vehicle to actually pick up a little speed as you are going along. kinda letting the engine do your brakeing for you, don't downshift to do it, just kinda coast along. if it is going to smoke, it will, as soon as you floor it. any hill, any gear., like mabe a ramp off the freeway or something. are you getting any oil in your air cleaner?
It does not burn a large amount of oil. I have actually been using it to commute to work the past week (100 miles/ day) and the oil is still up high from when I changed it last weekend. I did the valve cover gasket about two years ago and it is still not leaking...the front main looks like it might be blowing some oil though. The only signs I have of an internal oil leak are the coated plugs and the big blue puff at start up. I am thinking of sinking a little money into the engine and just thought I should try and fix these while I had it apart. I was looking at a header, 4 barrel, and swap to DS II distributor.
I tried the coast and floor trick a couple times on my ride home today, not even a hint of smoke...so I'm going to say my rings are good. Now time to decide what to do about the head. From the info I gathered it would probably be fairly economical to find a second head and have it worked, then I could convert over to the 4-brl, header and DS II at one time.
Thank you for the input, and I'm sure I will start or contribute to existing threads for help on this project.
