1993 F150 E4OD Problems
would this be a good purchase or not
http://cgi.ebay.com/ebaymotors/Ford-...Q5fAccessories
as for the parts match.....When I want to check out if a particular part from another year will fit, I will go to a parts site, like rockauto and compare parts numbers.
I am not sure if that part is a dealer only part or not, but I would at least check to see if you can find it cheaper. I remember it being around 50 bucks i think. Everything is pricey at the stealerships.
All the best with it!
well i had it completely rebuilt. found that the silonid body was damaged, the overdrive sun gear was not there anymore and that the overdrive planet was burned up. ordered a heavy duty overhaul kit, heavy duty/stock stall torque conver, electronic shift kit and a couple other things to it. its works really really well now. best its ever been since i owened the truck. so everything is good now, now i have to raise the motor and replace the oil pan gasket. now i have almost 2100 miles on it and i dont have a single complant about the tranny, except it didnt help my gas milage any, lol.
BDFD
16
01-08-2017 03:01 PM
Transam461
09-10-2016 12:58 PM
lievense81
08-26-2015 06:38 PM
