Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1987 - 1996 F150 And Larger F-Series Trucks
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1987 - 1996 F150 And Larger F-Series Trucks SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 08-27-2009, 10:09 PM
AaronOregon AaronOregon is offline
AaronOregon is starting off with a positive reputation.
Hard starting after sitting overnight. New fuel injectors?
Hey guys. I just installed a new crate engine. Well, why I was at it, I put on a lot of new parts and one of them was some new fuel injectors from a fuel injection company I found on ebay. All 8 were only $99 with a lifetime warranty. Well, the first thing I noticed when I got them in the mail was how much lighter-weight they were. They looked really cheap and cheesy compared to the ford ones, but I figured they would be ok. Well, the truck runs good except a slight stumble in drive and it starts hard after sitting overnight like fuel is running back. Once it is started for the day it does ok. Should I put the original old ones back in or what? Any ideas? Thanks....
Aaron
  #2 (permalink)
Old 08-28-2009, 05:39 PM
Nobody know anything???
  #3 (permalink)
Old 08-28-2009, 06:00 PM
subford's Avatar
subford subford is offline
subford has a great reputation on FTE. subford has a great reputation on FTE. subford has a great reputation on FTE. subford has a great reputation on FTE. subford has a great reputation on FTE.
Quote:
What year and engine size?
__________________
95 F150 302 4R70W EB EX-CAB
94 F53 460 E4OD COACHMEN SANTARA RV
83 F150 Flare Side 351W AOD
77 F250 351M-2V NP 435/4 Speed 4X4
subford@gmail.com
Bill K, Kansas Chapter
  #4 (permalink)
Old 08-28-2009, 07:02 PM
DBGrif91's Avatar
DBGrif91 DBGrif91 is online now
DBGrif91 is starting off with a positive reputation.
Well, as long as you don't damage any of the o-ring seals, you won't lose anything but time changing out the injectors to see if it makes any difference.
What do you mean "slight stumble in drive"?
As far as if fuel is leaking back or not, just turn the key to ON and leave it for a second or two to give the fuel pump time to prime the lines, then see if it starts any easier.
__________________
"Official Project Stages: (1) Uncritical Acceptance. (2) Wild Enthusiasm (3) Dejected Disillusionment. (4) Total Confusion. (5) Search for the Guilty. (6) Punishment of the Innocent. (7) Promotion of the Non-participants."
-Unknown
  #5 (permalink)
Old 08-28-2009, 08:46 PM
danr1 danr1 is online now
danr1 is gaining momentum as a positive member of FTE. danr1 is gaining momentum as a positive member of FTE.
When you tested the fuel pressure (engine off) and then turned of the key to de-energize the pump, does it hold pressure within 5lbs of specified value (35 to 45lbs) for 1 minute?
If not it could mean the injectors are leaking down, other causes to but you do suspect the cheap feeling set of injectors you received.
If you need a full list of causes just ask.
__________________
87, 94, 95 F250
89 Bronco II
05 Chevy Impala
  #6 (permalink)
Old 08-31-2009, 04:49 PM
Greedy River Greedy River is offline
Greedy River is starting off with a positive reputation.
I have a 96 F-150 302 and I just changed the fuel tank and fuel filter last week and noticed the same thing,no stumbles but overnight when I try to start it fails or runs rough for a couple of seconds the dies.On the second try its right there no troubles after that.
I came on here to find some answers myself,I was thinking that maybe my fuelpump is getting weak or maybe air in my lines?
Oh,this morning I turned the key ahead but only far enough to turn on the fuel pump,then I turned the key off.At that point I turned the key on and tried to start but it failed,tried again and it was fine.
  #7 (permalink)
Old 09-05-2009, 11:07 PM
BigAl 79 BigAl 79 is offline
BigAl 79 is starting off with a positive reputation.
Hey Aaron,
What did you find was the problem? I have 1996 460 gas that does the same thing. Was a bad injector or losing pressure?
Alex
  #8 (permalink)
Old 09-06-2009, 01:01 AM
muscletruck7379's Avatar
muscletruck7379 muscletruck7379 is offline
muscletruck7379 is gaining momentum as a positive member of FTE.
possibilities:
bad pressure regulator
bad injector(s)
bad check valve(part of fuel pump)
put a pressure guage on engine, and like danr said watch the pressure. if it does leak down, put a clamp on the pressure (after energizing pump) and return line and check pressure. if it still drops, pull the injectors out of the manifold so you can put pressure to them while watching the nozzles and check and see if any are leaking, if so replace them, if not replace your pressure regulator.
edit: first remove vacuum line that runs to the regulator and check for fuel in it. if there is fuel, replace the regulator
__________________
1973 f250 highboy 4x4
1984 full size bronco, megasquirted 300 on the way!
1988 f150 extended cab 4x4
1984 mercury capri, 5.0 conversion
1961 ford falcon, all stock, in family since '68
Tags
1998 , 460 , causeing , f150 , ford , fuel , hard , injection , injectors , leaking , night , problems , sitting , starting , starts
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
