Emergency flasher does not work - Ford Truck Enthusiasts Forums
Old 08-27-2009, 09:12 PM
Dialtone Dialtone is offline
Dialtone is gaining momentum as a positive member of FTE.
99 F150 4.6 single cab.
The emergency flasher system is not working properly. When the switch is pressed it may/ may not flash once then stop cold.
Trun signals work just file.
I can hear/feel a relay under the dash activate for both flashers and turn signals but was wondering if a seperate relay unit is used for the different functions. Haynes manual electrical diagram is no help as it does not show the flasher relay(s).
Or is this just a bad multi=function switch problem.
Any guesses?
Thanks
Dialtone
Old 08-28-2009, 06:16 PM
fordmerc's Avatar
fordmerc fordmerc is offline
fordmerc is starting off with a positive reputation.
I would guess multi function switch.
Old 08-28-2009, 08:35 PM
Mawk Mawk is offline
Mawk is starting off with a positive reputation.
My guess is a bad flasher relay.
Left hand instrument panel on the fuse panel.
F53 brake light and hazard flashers failure meporsche 1999 to 2016 Super Duty 5 04-03-2016 04:05 PM
No turn signals or hazard lights carlsson 1999 to 2016 Super Duty 1 07-09-2015 05:06 PM
'99 Dodge Caravan Turn Signals????? BPofMD General Automotive Discussion 3 05-12-2010 02:34 PM
Front turn signals not working jquick1 1973 - 1979 F-100 & Larger F-Series Trucks 6 01-31-2010 06:12 PM
Turn signals Ford150/428/dud Electrical Systems/Wiring 4 06-15-2007 03:16 PM
Tags
150, 1995, 2000, 2001, 2003, 250, 99, emergency, f150, flasher, flashers, ford, problem, relay, signals, turn
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
