Front end noise when turning - Ford Truck Enthusiasts Forums
Old 08-27-2009, 08:53 PM
lloydmiiller lloydmiiller is offline
lloydmiiller is starting off with a positive reputation.
I have a 2002 mercury mountaineer with 76000 mi that has a grinding noise or rubbing noise when I make a right hand turn it has stock size tires so thats not the issue could someone try to point me in the right direction. The local ford dealer drove it like a grandma and it didnt do it. Told him it does it at higher cornering speeds but he didnt listen. Had other people here the same noise so im not hearing things. thanks for your time
Old 08-27-2009, 10:09 PM
aquanaut20's Avatar
aquanaut20 aquanaut20 is offline
aquanaut20 is starting off with a positive reputation.
Check the end play in the front hubs (bearings)
growling noise with intermittent metal grinding noise in front end resq302 Explorer, Sport Trac, Mountaineer & Aviator 9 09-29-2015 07:41 PM
Rubbing/Grinding noise when turning SD Dually 1999 to 2016 Super Duty 9 05-21-2014 12:39 PM
intermittent wheel bearing noise. could it be something else? 96f15013ddie 1987 - 1996 F150 & Larger F-Series Trucks 3 10-10-2013 10:04 AM
growling/rubbing noise in front end AzViper General Diesel Discussion 2 02-18-2008 11:08 AM
Two new noises shadowdd Excursion - King of SUVs 2 04-04-2006 07:01 PM
Tags
2002, axle, end, f150, ford, front, grinding, mercury, mountaineer, noise, noisy, rubbing, sound, tire, turning
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
