Another piece of the puzzle
Removed all of the old wire harness and started installing the new harness, so far its coming along pretty good, but with just about everything so far more work is involved. Like the headlight buckets or should I call them rust buckets. LOL. I'll have them repainted in the next couple days. By the end of tomorrow I should have the new harness in place.
Sam
Didn't think anyone would be interested in pictures of the wiring installation. I'll try and post some later today. FYI some of my other on going projects, gas tank flush de-rust and line, new petcock, new fuel pump, lines and filters, SS fuel log with silver soldered joints, new oil filter and the modification of my big buck throttle linkage. Oh ya the 9 inch rebuild. Theres more but thats for later.
I'd also like to see that fuel log update..
besides.. I like to bug people to tell us what they are doing.. keeps the energy up..
Sam
very nice.. those 'before' pictures... did oyu clean it, then put it back to old, and now changing to new? Never seen an original behind the dash look that good!!..
I gave up on posting pics thru FTE.. too many restrictions and just not works..
I upload to photobucket, then use [IMG] links in my posts..
Sam
Sam
Spent the good part of the day chasing down a few screws after I did a little surgery on the new throttle linkage the rest I spent on the fuel log. The nice part of this linkage is that it's beefy and should keep adjusting to a minimum, but it made me change my plans on the fuel log a few times.
[/IMG]
[/IMG]
#29
#30
Hi Marty,
Nice clean installation.. The VDs are installed completely correctly...Mind if I make a few suggestions to possibly save you some work or $$$?
First, lets get oriented. In your pictures you have gauges at 2, 4, 8, and 10 o'clock with the amp gauge indution loop being on the back of the 10 o'clock gauge.
First, you need to run a second power bridge from the 4 o'clock gauge upper right lug (where the long bridge comes over from the 8 o'clock gauge) to the lower right lug of the 2 o'clock gauge. As it is now you don't have any way to run power up to that 2 o'clock gauge. Tha is of course unless youare running seperate power wires to each gauge.
Also, I strongly recomment you DO use a third VD on the 8 o'clock gauge. If you want a strong reliable install you'll need a third one - heat is one reason plus, you really don't have any good way to hook these with the bridges and have them be reliable if you have two hooked in series.
Third, unless you have replaced the circuit breakers with 12 volt breakers, you can't use them. The are going to be wattage sensative and at 12 volts if you have an over power they won't kick in until you pass 70 amps through the 35 amp CB etc. You will need to get rid of those completely and use a fuse block (unless, like I said they are new ones designed for 12 volt.
