Can you use 18 volt batteries in 14 volt Dewalt tools? - Ford Truck Enthusiasts Forums
Old 08-27-2009, 05:04 PM
Wagion's Avatar
Wagion Wagion is offline
Wagion has a very good reputation on FTE.Wagion has a very good reputation on FTE.Wagion has a very good reputation on FTE.
I need to buy new batteries for my little drill and was wondering if I can use the 18 volt batteries in the 14 volt drill I know they will fit but will they burn it up? The reason is the 18 volt batteries come in a two pack for $100 and the 14 are $85 each?
Old 08-27-2009, 05:11 PM
mountaineer27's Avatar
mountaineer27 mountaineer27 is offline
mountaineer27 is gaining momentum as a positive member of FTE.mountaineer27 is gaining momentum as a positive member of FTE.
18 volt batteries shouldnt fit the 14v drills. there designed to not fit so you wont burn up the drill. i have both and the 18v batteries dont fit
Old 08-27-2009, 06:27 PM
jake00's Avatar
jake00 jake00 is offline
FTE is my crack
jake00 has a brilliant futurejake00 has a brilliant futurejake00 has a brilliant futurejake00 has a brilliant futurejake00 has a brilliant futurejake00 has a brilliant futurejake00 has a brilliant futurejake00 has a brilliant futurejake00 has a brilliant futurejake00 has a brilliant futurejake00 has a brilliant future
I "fit" 14.4's on my 12v, I've been doing it for the past 10 years, never had a problem.
I'd imagine you can do the same thing
Old 08-27-2009, 11:52 PM
rollerstud98's Avatar
rollerstud98 rollerstud98 is offline
rollerstud98 has much to be proud ofrollerstud98 has much to be proud ofrollerstud98 has much to be proud ofrollerstud98 has much to be proud ofrollerstud98 has much to be proud ofrollerstud98 has much to be proud ofrollerstud98 has much to be proud ofrollerstud98 has much to be proud ofrollerstud98 has much to be proud of
ugh, throw the dewalt out and get a real tool
Old 08-28-2009, 10:27 AM
ddrumman2004 ddrumman2004 is offline
ddrumman2004 is gaining momentum as a positive member of FTE.ddrumman2004 is gaining momentum as a positive member of FTE.
Quote:
Care to name a few "real" tools that the average "joe" or homeowner can afford? Not the pros out there, just us weekend handymen..
Old 08-28-2009, 09:07 PM
shorebird's Avatar
shorebird shorebird is offline
shorebird has a superb reputationshorebird has a superb reputationshorebird has a superb reputationshorebird has a superb reputationshorebird has a superb reputationshorebird has a superb reputationshorebird has a superb reputationshorebird has a superb reputationshorebird has a superb reputationshorebird has a superb reputationshorebird has a superb reputation
I have both Dewalt and Rigid cordless drills. The Dewalt was given to me without batteries and I purchased the two pack at Home depot. Works fine and is in my tool box now. Would I buy one if I had to pay full price? No as I have a Rigid 1/2 inch chuck lithium powered hammer drill that can handle much more. The Rigid batteries have a lifetime warranty. The Dewalt batteries do not. The Rigid is available at Home Depot from their Reconditioned sales for only $110.00. http://www.homedepot.com/h_d1/N-5yc1...atalogId=10053 That is a deal that is unbeatable.
Old 08-28-2009, 10:05 PM
Rigid like shorebird says. Although I do find them heavy but I haven't seen the lithium ion ones yet. I still run panasonic drills and they are my favorite but are pricey.
Old 08-28-2009, 11:29 PM
Lead Head Lead Head is offline
Lead Head is a name known to allLead Head is a name known to allLead Head is a name known to allLead Head is a name known to allLead Head is a name known to allLead Head is a name known to all
I put an 18 volt battery on the gutted circuitry and motor of a 12v drill, and the transistor that actually drives the motor burned out and popped instantly. I can't imagine a 14v transistor on that drill lasting much longer then the 12v one.
My Dad has one of those Makita Lithium Ion drills, a lot of power for its size, and very compact and well balanced. Battery does not last that long, but it only takes 15 minutes to charge.
1950 ford truck 6 volt or 12 volts beckman 1948 - 1956 F1, F100 & Larger F-Series Trucks 16 09-14-2016 03:43 PM
Cordless tools - ideas and reviews four-sixty-power General NON-Automotive Conversation 4 04-14-2014 05:44 PM
voltmeter reading CB3 1973 - 1979 F-100 & Larger F-Series Trucks 8 07-03-2013 02:49 PM
8 volt battery in 6 volt system kermit123 1948 - 1956 F1, F100 & Larger F-Series Trucks 14 01-08-2011 10:11 AM
Stator On Alternator Not Putting Out Volts jim4 1973 - 1979 F-100 & Larger F-Series Trucks 15 12-26-2008 04:03 PM
Tags
14, 14volt, 18, batteries, battery, cordless, dewalt, drill, drills, fit, ion, li, ridgid, volt, vt
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
