Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > 2004 - 2008 F150
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
2004 - 2008 F150 2004, 2005, 2006, 2007 and 2008 Ford F150's with 5.4 V8, 4.6 V8 or 4.2 V6 engine SPONSORED BY:
  #1 (permalink)
Old 08-27-2009, 10:23 AM
evilwayz7's Avatar
evilwayz7 evilwayz7 is offline
2005 Ford F-150
evilwayz7 is starting off with a positive reputation.
Question Stock 6 Disc in dash MP3/CD changer
I own a 2005 F150 with the 6 disc in dash CD changer. I have been having problems with it loading and unloading discs. At first it wouldn't load the disc unless I pushed it in fast. Then it would not eject the disc. I would have to hit load a few times and it would work. Now it just says CD error. It won't read the disc, it won't eject, it won't change to another disc. When I would hit the eject button or the load button it was saying INITIALIZING across the screen but didn't do anything. Now it just says CD error. Is it time for a new stereo or can I pull it out and clean it and get it going again? I also want my CD's back. Thanks for any input.
  #2 (permalink)
Old 08-27-2009, 12:25 PM
hcbph hcbph is offline
2007 Ford F-150
My Garage
hcbph is starting off with a positive reputation.
CD player
Sounds like you're having some of the same issues I had with the one in the truck I just bought. I ended up taking mine in under warranty. I did see somewhere there is a way to 'reinitialize' the unit but I can't find it right now, didn't work on mine anyway.
Mine was replaced under warranty
Paul
  #3 (permalink)
Old 08-27-2009, 01:41 PM
VFR_Man's Avatar
VFR_Man VFR_Man is offline
Garage is empty, add now
VFR_Man is starting off with a positive reputation.
If you want a durable stereo, I'd say yank that 6 disc and put something aftermarket in that you trust.
Those 6 disc units just have too many parts in too small of a volume and have to do too much work to ever last for long. I dread ever being forced to buy one because I want some other accessory/package on a vehicle.
__________________
2007 F150 SCab Lariat 5.4L 4x4
1995 Ranger XLT 4.0L 4x2 LB
  #4 (permalink)
Old 08-27-2009, 01:49 PM
Tylus's Avatar
Tylus Tylus is offline
Nuke Mechanic
2006 Ford F-250
Tylus has much to be proud ofTylus has much to be proud ofTylus has much to be proud ofTylus has much to be proud ofTylus has much to be proud ofTylus has much to be proud ofTylus has much to be proud ofTylus has much to be proud ofTylus has much to be proud ofTylus has much to be proud of
sounds like time for a new radio.
you are lucky though, Ford went modular with their radios.
You can pull the radio from a plethora of Ford.
03-08 Expy/Navi
04-08 F-150/Mark LT
05-08 Econoline
05-07 Fusion/Taurus
05-09 Mustang
__________________
MM1 (SS) - 688 Class - First Flight Tough
2006 F-250 Lariat CC w/PSD <-- Build Thread
2012 Flex Limited <-- 17 mpg city, 27 mpg highway.
  #5 (permalink)
Old 08-28-2009, 01:49 PM
evilwayz7's Avatar
2005 Ford F-150
I wanted a new stereo anyways for a while but was happy with the sound so I never replaced it. I pulled the deck and removed the cover to expose the inside of the stereo. I had to manually remove the discs once the stereo initialized. Just one disc was jammed in there and wouldn't eject completely. I realized that the small gears and rollers that grab the cd to load and unload are now too weak to move the cd. It just makes noise but won't load the disc. If I force in the cd it just gets misaligned with the motor that spins the cd and starts making all kinds of noise like its just eating up the disc. I gave up and decided it is now a pile of junk and will replace with aftermarket. Thanks guys.
Tags
2002, 6disc, cd, changer, disc, disk, error, ford, jammed, load, mp3, mustang, problems, shows, stock, wont
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
