Delaware Chapter Join Chapter, Leader: pbsdaddy
Paint
Old 08-27-2009, 08:33 PM
skirk55's Avatar
skirk55
skirk55 is offline
Paint
This Sunday when I install my toys I am going to paint the undercarriage of my truck. Do I use black paint or a rubber undercoating?
Old 08-27-2009, 08:40 PM
fire240's Avatar
fire240
fire240 is offline
I would use the paint Sam. But that is just my opinion.
Old 08-27-2009, 09:23 PM
skirk55's Avatar
skirk55
skirk55 is offline
Hi Shaun I need about 6 cans of paint to spray my truck every year. I just want the best type of paint that will hold up. Winter will set in soon.
Old 08-27-2009, 09:28 PM
fire240's Avatar
fire240
fire240 is offline
I do know that you can get the line-ex lining put on it as an indercoat but I am not sure what that would cost. I have the line-ex liner in the new truck and it does great.
Old 08-27-2009, 09:33 PM
Surge08's Avatar
Surge08
Surge08 is offline
I would say rubber, it can take more of an beating then the reg paint would
Old 08-28-2009, 04:38 AM
SCRWDRVR's Avatar
SCRWDRVR
SCRWDRVR is offline
"Obsessed"
If your using it for protection I would use undercoating, if your using it for looks I would use paint. I respray my frame and such for shows every now and then but I undercoated my rear wheel wells so they would be protected.
Old 08-28-2009, 04:51 AM
66fdtrucknut's Avatar
66fdtrucknut
66fdtrucknut is offline
I would definitely go with paint on a frame. At least with paint you can see problems coming.
Charlie
Old 08-28-2009, 06:47 PM
skirk55's Avatar
skirk55
skirk55 is offline
I want to spray it to look good. My Pro Comp MX6 shocks must have been painted with white wash! My truck sits up and you can see the undercarriage. It makes the truck look much better. I am going to paint with undercoat spray under the bed. The rears,frame and everything else black paint. What is better flat black or glossy?
Old 08-28-2009, 08:03 PM
SCRWDRVR's Avatar
SCRWDRVR
SCRWDRVR is offline
"Obsessed"
I use gloss on mine, I think it looks better
Old 08-28-2009, 09:01 PM
66fdtrucknut
Same here.
Old 08-28-2009, 09:16 PM
jr32560's Avatar
jr32560
jr32560 is offline
flat paint of any type will collect dirt worse gloss seems to repel dirt and water better
Old 08-29-2009, 02:21 PM
skirk55's Avatar
skirk55
skirk55 is offline
Thank you all for the help. Six cans of spray paint will do it .
Old 08-29-2009, 03:09 PM
80351's Avatar
80351
80351 is offline
Hey Sam if you haven't already or you can still do it over the paint I am very fond of the DupliColor Spray bedliner. It sticks where ever you spray it and is very durable. I even did the steel wheels on my full sized Bronco with it.
BIGskinny
24
06-02-2011 03:09 PM
codafisler
03-12-2011 12:06 AM
AmnStroker
Paint & Bodywork
02-16-2010 10:19 PM
Young_unn
04-11-2006 12:35 PM
Crazydan
03-29-2006 02:17 PM
Quick Reply: Paint
