DTC Code #327 - Ford Truck Enthusiasts Forums
Ranger & B-Series All Ford Ranger and Mazda B-Series models
DTC Code #327
Old 08-26-2009, 04:24 PM
Gerald Andre Gerald Andre is offline
Gerald Andre is starting off with a positive reputation.
DTC Code #327
I have a 1993 2.3L Ford Ranger XLT.
When I turn on my ignition, the RPM's accelerate up to 3000-4000 without having to press on the accelerator. They remain at that RPM during the idle.
I have run the KOEO check light test and the following code was retrieved:
#327 - EGR valve position circuit below minimum voltage
Where should I now concentrate my attention?
I have cleaned the MAF sensor with electrical cleaner and that has not corrected the problem.
I am now looking at replacing the EGR Vacuum Regulator (EVR) Solenoid. Anyone else have this problem before?
<input id="gwProxy" type="hidden"><!--Session data--><input onclick="jsCall();" id="jsProxy" type="hidden">
Old 08-26-2009, 07:20 PM
Rockledge's Avatar
Rockledge Rockledge is offline
Rockledge is a splendid one to beholdRockledge is a splendid one to beholdRockledge is a splendid one to beholdRockledge is a splendid one to beholdRockledge is a splendid one to beholdRockledge is a splendid one to beholdRockledge is a splendid one to behold
A code 327 usually means a bad DPFE sensor.
ABS Light and Speedometer jeffleard 1997 - 2003 F150 1 12-07-2013 05:21 AM
1975 Ford Ranger door weatherstrip flako 1973 - 1979 F-100 & Larger F-Series Trucks 19 03-04-2011 02:07 PM
code 332 maxtruck00 1987 - 1996 F150 & Larger F-Series Trucks 18 06-08-2010 09:38 PM
91 F150 XL. Check engine light problems Offroadracer426 1987 - 1996 F150 & Larger F-Series Trucks 9 03-09-2010 07:45 AM
302 V8 Engine code question sidala Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 3 06-12-2005 08:24 PM
Tags
1997, 327, 92, 93, code, dtc, egr, f150, f250, ford, ranger, sho, taurus, test, trouble
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
