Go Back   Ford Truck Enthusiasts Forums > Super Duty/Heavy Duty > Excursion - King of SUVs
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 08-25-2009, 11:43 PM
Gmcbuffalo Gmcbuffalo is offline
Gmcbuffalo is starting off with a positive reputation.
6.0 L hesitation
I have a stock 05 EXC 6.0 Liter lately I have noticed a hesitation on slow acceration, and even at 30 MPH when adding slight throttle. Dealership says no codes. I first noticed it when we had 107 deg temps but today it was raining and cool. It's like you are accerating and nothing happens and then bang it jumps in speed. Any ideas?
GregM
  #2 (permalink)
Old 08-26-2009, 12:52 AM
Stewart_H's Avatar
Stewart_H Stewart_H is offline
Never fry bacon NAKED!
2002 Ford F-250
My Garage
Stewart_H is a splendid one to behold Stewart_H is a splendid one to behold Stewart_H is a splendid one to behold Stewart_H is a splendid one to behold Stewart_H is a splendid one to behold Stewart_H is a splendid one to behold Stewart_H is a splendid one to behold
I'm sure the guys with 6.0L powered Excursions will chime in if they have any idea's, but in the mean time, you'll get a lot more responses if you post this question in the 6.0L PSD forum.
Stewart
__________________
The Brotherhood of FTE <~click the link
1999 F150 Lightning: WMS built block, 6lb lower, Monsterbox, Truetrac, CF driveshaft
2002 PSD F250 SC 4x2: 38R, AC codes, MBRP 4", AFE, JWVB, Riffraff HPX, CCV, and boots, ITP OBA, Live Tuned by Jody
2000 PSD Excursion 4x4: John Wood 4R100, F5, MBRP 4", AFE, BDP 1.0, ITP OBA and Pre-Pump mod, V & B code springs, Hellwig rear sway
  #3 (permalink)
Old 08-26-2009, 08:05 AM
katiesdad7 katiesdad7 is offline
katiesdad7 is starting off with a positive reputation.
Sounds to me like the vanes on the turbo are sticking but you would get a code for that. I had my turbo replaced at 15k for that.
__________________
2005 Eddie Bauer 4x4 w/6.0 PowerSlot Cryo Rotors up front, Hawk LTS pads all around, Bi-Xenon HID's.
Who said size doesn't matter?
  #4 (permalink)
Old 08-26-2009, 09:16 AM
Toreador_Diesel's Avatar
Toreador_Diesel Toreador_Diesel is online now
2001 Ford Excursion
Toreador_Diesel has a good reputation on FTE. Toreador_Diesel has a good reputation on FTE.
Quote:
Stewart
Sounds to me like the Turbo vanes are sticking, but I'll move this down to the 6.0 forum to get you some better answers.
__________________
If you live in Texas and need help with your truck, PM me.
FTE Excursion Forum Mod
Death Row Inmate #21
2001 X PSD Limited
6637 Filter
203* Thermo
SCT X-Cal2
4 in. MBRP
AT 4040
HPX
Sonnax/Tricum Kit
'04 TT Mirrors
6' PROcomp lift
35' BFGs
Bosch HIDs
4.10 Gears
WW
Walbro GSL392
  #5 (permalink)
Old 08-26-2009, 02:44 PM
JaySVX's Avatar
JaySVX JaySVX is online now
2004 Ford Excursion
JaySVX is gaining momentum as a positive member of FTE. JaySVX is gaining momentum as a positive member of FTE.
Take your throttle body off and see if it isn't all gunked up. i've seen some nasty buildups on those. If the turbo isn't spinning freely it make take some extra beef to get it going, then once it's going it's fine, so it might be the bearings or shaft play in there. Keep in mind you have turbo lag, which is made worse by hauling a large or oversized load, check to make sure my ex-wife isn't in the back, that'll really slow you down.
__________________
2004 Ford Excursion 6litre PSD
Quote:
Originally Posted by ncheavymetal View Post
But I have an excursion and don't concern myself with matters such as "how much does it weigh?"
Quote:
Originally Posted by Maxium4x4 View Post
I would drive 1,500 miles out of my way rather than to walk through the front doors of any WalMart, OH look! TruckNutz isle 5
  #6 (permalink)
Old 08-26-2009, 03:21 PM
PeeWeeRacer PeeWeeRacer is offline
PeeWeeRacer is starting off with a positive reputation.
I'd look into the EGR valve!!
  #7 (permalink)
Old 08-27-2009, 08:12 AM
jackassjeeper97 jackassjeeper97 is offline
jackassjeeper97 is starting off with a positive reputation.
I agree sounds like turbo is coked up,may want to have it check out ford has a kit that cleans that out but it is pretty involved. As far as EGR not sure when my egr and cooler went bad the only thing I had was it started smoke really bad and would only do it once the truck reached temperature and when the valve would open and close. Just my experience
  #8 (permalink)
Old 08-28-2009, 11:33 PM
BigRy BigRy is online now
BigRy is starting off with a positive reputation.
Do you use an additive, I put in too much one time with an accelerated cetane booster, and the truck ran like crap, I had to run it down to about a half a tank, refilled it, and since then no problems. When it first happened I took it to the dealership and they couldnt find any codes either.
__________________
________
Ryan
05 Limited 6.0 Excursion
Don't you just love the smell of diesel in the morning......
  #9 (permalink)
Old 08-29-2009, 12:27 AM
scottf4444's Avatar
scottf4444 scottf4444 is offline
This Gets Addicting
scottf4444 has a good reputation on FTE. scottf4444 has a good reputation on FTE.
Quote:
Actually...with all due respect, I'm going to go opposite on this one. I had the same issue, crap CA diesel fuel was messing up my injectors. I dumped an entire bottle of RBP additive into a full tank of diesel, then two ounces every time I fill up. Cleaned it out, got rid of any water, don't know if there was any water but hey...can't hurt, and I have been running great ever since - been probably 3 years.
I have a fleet of trucks with just about every modern diesel in them - a Cummins Dodge, a DuraCRAP Chevy, a 7.3, a 6.4 and my daily driver 6.0 Ex. I put a bottle of additive in each of them and when we filled them up, drop an ounce or two in. Every person who drives them could tell a difference.
If you dont use an additive, maybe try one??? Cheap fix if that is the case.
Good luck!
__________________
<a href=http://www.ford-trucks.com/forums/image.php?type=sigpic&userid=367560&dateline=1233850778 target=_blank>http://www.ford-trucks.com/forums/im...ine=1233850778</a>
  #10 (permalink)
Old 08-29-2009, 07:24 PM
XHunter's Avatar
XHunter XHunter is offline
XHunter is starting off with a positive reputation.
there is a TSB for cleaning/reconditioning the turbo on our trucks. mine was in a few months ago for white smoke (egr cooler replacement) they did the TSB on it for the turbo....didn't meet the standards and they put a new turbo (recon) in under warranty. so if you are still under warranty they probably give you a new turbo...........
__________________
Black '05 Excursion PSD Limited 4x4.
Built 9/26/05, purchased 12/1/05.
Airaid intake with "zoodad" mod, MBRP 4" Turbo back, no kitty & Bully Dog downloader, Acufab power elbow, Mag Hytec F & R diff covers & trans pan. Helwig rear sway bar 55k miles.2" Hanger leveling lift. Bilsteins, 20x9 ProComp Extreme Alloys w/ 305/55R20 BFG All terrains
  #11 (permalink)
Old 09-07-2009, 02:17 PM
Thanks guys. get this the service writer at the dealership told me that since I tow my X behind my motorhome the Turbo is getting plugged up with junk from the road. I must have one bad air filter.
  #12 (permalink)
Old 11-02-2009, 01:16 PM
2001 Ford Excursion
Quote:
What ended up happening?
__________________
2001 X PSD Limited
6637 Filter
203* Thermo
SCT X-Cal2
4 in. MBRP
AT 4040
HPX
Sonnax/Tricum Kit
'04 TT Mirrors
6' PROcomp lift
35' BFGs
Bosch HIDs
4.10 Gears
WW
Walbro GSL392
  #13 (permalink)
Old 11-03-2009, 12:42 AM
I also have had this dime size oil leak, over the year they have replaced (or at least told me) every O-ring on the engine. Findly they ran out of O-rings and agreed I had a bad short block milling where the oil pan attached. During the replacement of the short block they found the turbo was not turning properly, so they replaced the insides of the turbo and the problem was solved. So was the oil leak.
GregM
  #14 (permalink)
Old 11-03-2009, 01:14 AM
2001 Ford Excursion
GregM
Nice!
Glad you're fixed!
__________________
2001 X PSD Limited
6637 Filter
203* Thermo
SCT X-Cal2
4 in. MBRP
AT 4040
HPX
Sonnax/Tricum Kit
'04 TT Mirrors
6' PROcomp lift
35' BFGs
Bosch HIDs
4.10 Gears
WW
Walbro GSL392
  #15 (permalink)
Old 11-03-2009, 07:19 AM
Told you it was the turbo. I had mine replaced at 15k. I didn't notice any difference in the way that it drove but I got a check engine light.
At least it's fixed. Was it repaired under warranty?
__________________
Tags
2005 , 250 , 60 , 60l , block , booster , cetane , clean , ford , lag , psd , ran , replaced , rid , short , turbo
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
