'86 F150 302 EFI Fuel Pressure Loss
Old 08-24-2009, 11:41 PM
steve.t's Avatar
steve.t
steve.t is offline
My '86 F150 302 EFI has a fuel pressure problem. When started cold, pressure is 35psi, but after 10-15min. of driving/idling drops to 10psi; then runs rough/no power. If try to re-start after short time (~30min.) still has low pressure. If wait several hours, starts out at 35psi again. Replaced frame (high pressure) fuel pump, relay, fuel filter. No change in problem. Problem is same on either of the dual tanks. Anyone have an idea of what the problem could be?
Old 08-25-2009, 06:38 PM
Franklin2's Avatar
Franklin2
Franklin2 is online now
Received 1,654 Likes on 1,337 Posts
Pull the vacuum line off the fuel pressure regulator. If there is gas in the line, then replace the regulator.
Old 08-25-2009, 08:37 PM
steve.t's Avatar
steve.t
steve.t is offline
Thanks for suggestion Franklin2. Going to repair shop to bring it home again - hopefully last time for a while. I understood they discovered a hole in the inside tank line that caused the fuel pressure loss. I don't know why it would cause a drop in pressure after 10min, but they said the tank pump was just pumping the fuel back into the tank. Hopefully it's fixed now.
Steve
Old 08-26-2009, 09:14 PM
steve.t's Avatar
steve.t
steve.t is offline
Picked it up today. Hole in inside tank line was problem - the line was badly deteriorated and falling apart. The hole was about size of dime. Runs great now.
Old 02-09-2014, 09:18 PM
kc5wxc's Avatar
kc5wxc
kc5wxc is offline
so this was a line inside of a tank that was the problem?
Old 02-10-2014, 11:48 AM
tempest411's Avatar
tempest411
tempest411 is offline
What a pain that must have been! I've read a lot the last few years about the increasing problem of the alcohol in today's fuel blends destroying fuel lines in older vehicles like ours. There's a unique type of fuel line for use on the INSIDE of fuel tanks. Did they mention that to you? If your invoice shows a 12" piece of fuel line for what seems like way too much money, that would be it.
Tugly
130
07-20-2020 11:56 AM
Tugly
223
08-18-2019 07:36 AM
86Stepside
19
10-12-2015 08:43 PM
Bear999
13
10-03-2015 09:23 AM
86stepsideF150
06-28-2010 09:23 PM
Quick Reply: '86 F150 302 EFI Fuel Pressure Loss
