You really need to get a FSM(Factory Service manual) to do the job correctly.You can usually find one on ebay,and easily find one on CD.
The CD is okay,if you have the time to cruise all the pages,and print out what you need,but the Manual itself is much easier to use. Also,if 0ne head gasket is bad,the other is likely to follow. Since the intake,and all that stuff on the top end has to come off anyway,its wise to replace both at the same time.
__________________
Air Transport Radar Tech
