Wheel bearing causing ABS to act up ?
WOW, It sounds like you are posting the exact same issue I am having.
I posted it a few times now with no results.
I have the same truck and mileage as you.
I would get the ABS kicking in at 10KM/hr and there would be no ABS light on at all or no check engine light either.
I read on another post just to pull fuse#25 for the ABS out from below the dash. The ABS light now stays on, but I have no ABS working at all. It brakes OK like this. It sure would be nice to have it back for the winter. I just picked up a rear hub ABS sensor to replace this weekend as this seems to be a solution to some of the posters. It is the cheap way to test right now at only $30. Hope it works.
I have NO PLAY at all or no sounds at all from my front hubs.
The dealer says there are ABS sensor on each front bearing. These sensors are $230 each. (Holly SH?T) Ya, thats what I said. The whole front hubs with the sensors included are $330 each. That would be the way to go if you know which one to change. He said to try the rear sensor first and if that does not work, then bring it in to the dealer and have them figure it out. It may be a front sensor or something else altogether. Could be a grounding issue.
about 1/3 - 1/2 price if you get them on line.
http://cgi.ebay.com/ebaymotors/Ford-...=p4506.c0.m245
I checked all 3 sensors as well....did an ohm reading on them and from what I've read here I beleive they're ok. front sensors read 400 ohms and the rear read 1800 ohms. I'm not sure if that means they're good or not but I'm waiting to hear in another thread.
My abs problem is a little different now, since I messed with them the abs light now comes on when I start moving either forward or reverse.
When I turn off the truck and fire it up again the abs light goes away until I start moving again .
