about the front wheel bearings for a 2003 f-250 4x4 manual locking hubs? - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 08-24-2009, 08:37 PM
Buckboard6-300's Avatar
Buckboard6-300 Buckboard6-300 is offline
Buckboard6-300 is starting off with a positive reputation.
Question about the front wheel bearings for a 2003 f-250 4x4 manual locking hubs?
i am having problems with the front wheels bearings of the 2003 f-250 4x4 with manual locking hubs ..i am wondering what kind of bearings are they any details will help thanks
Old 08-24-2009, 11:16 PM
ken kenmnedy's Avatar
ken kenmnedy ken kenmnedy is offline
ken kenmnedy is gaining momentum as a positive member of FTE.
go to e bay and do a part search for your wheel bearing,,,,,or use this fourms search and see what you find there bettcha theres a lot of info here
Old 08-25-2009, 12:58 AM
EXv10 EXv10 is offline
EXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputation
Quote:
What kind of problems? Those bearings are sealed but can be greased. Do a search.
Old 08-25-2009, 10:14 AM
brian42's Avatar
brian42 brian42 is offline
brian42 is a splendid one to beholdbrian42 is a splendid one to beholdbrian42 is a splendid one to beholdbrian42 is a splendid one to beholdbrian42 is a splendid one to beholdbrian42 is a splendid one to beholdbrian42 is a splendid one to behold
Here's a link on how to grease them...
http://www.guzzle7pt3.com/nblube.php
Old 08-25-2009, 10:34 AM
ironmine ironmine is offline
ironmine is starting off with a positive reputation.
There are no standard, servicable wheel bearings like on your old truck. The wheel bearings are contained in a sealed wheel bearing/hub unit. This bearing hub is available locally, etc.
The link Brian gave is to re-pack/replace a needle bearing that sits in that bearing hub --- it is not a wheel bearing, but only a bearing to support the axle end.
Good luck.
Old 08-25-2009, 11:08 AM
okay...crap...how much does a new bearing assembly like this cost approx?
Old 08-25-2009, 11:15 AM
alright thanks guys
Old 08-25-2009, 12:02 PM
SpringerPop's Avatar
SpringerPop SpringerPop is online now
Too old to be too smart..
SpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputation
If you really want to grease the MAIN wheel bearings, not just the stub axle needle bearings, here's a link:
http://www.ford-trucks.com/forums/85...pics-here.html
However, if the bearings are already starting to go, this procedure won't be of much long-term value. It's a preventive-maintenance item, not a "fix".
Pop
Old 08-25-2009, 12:52 PM
Pop is right
Old 08-25-2009, 01:04 PM
brian42's Avatar
Dealer MSRP is around $350. The OEM hub assembly comes with new hub-to-knuckle studs (4 of them) and one new hub o-ring (yellow o-ring to seal the hub for the ESOF if you have it). IIRC Ford used coarse threads until 2003, then they switched to fine threads on the studs.
Depending on the dealership, it could be more or less (probably not less). Some dealerships have more of a markup above MSRP than others. I was able to get my hubs through my "regular" parts guys for about $250/each (I replaced both my front hub assemblies recently).
I'm not sure what shipping would be (they are not light), but you can try Ed to see what he can do for you. Here's his site:
http://www.trademotion.com/partlocat...?siteid=214072
Old 08-25-2009, 02:36 PM
1ATony's Avatar
1ATony 1ATony is offline
PREMIUM SPONSOR
1ATony is a splendid one to behold1ATony is a splendid one to behold1ATony is a splendid one to behold1ATony is a splendid one to behold1ATony is a splendid one to behold1ATony is a splendid one to behold1ATony is a splendid one to behold
If you need a new set of hub and bearing assemblies. Here's a link to them on our site.
If you have any questions there are allot of options with these trucks such as 4x4 vrs non 4x4, 4 wheel or 2 wheel ABS, single or dual rear wheel etc.,some models have five different hub choices they could have came with depending on the options package.
I can help you weed through it if you need help.
Tony
F-Series Ford Truck Hub Assemblies
__________________
Like us on Facebook
SHOP HERE FOR AWESOME BRAKE PAD AND ROTOR KITS - FREE SHIPPING
Old 08-25-2009, 04:55 PM
awesome help guys ill get figured out thanks for the info!
noisey hubs Mich6.0 6.0L Power Stroke Diesel 10 02-01-2016 11:26 AM
Repacking front wheel bearings on 4x4 truck airsoft1779 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 28 12-12-2012 11:09 PM
4x4 front wheel bearing replacement jackyoung 1987 - 1996 F150 & Larger F-Series Trucks 9 06-07-2011 02:45 PM
Hub Caps Don't Fit New Hubs biken4him 1999 to 2016 Super Duty 0 07-17-2010 12:07 AM
Front Wheel Bearing Replacement BDFD 1987 - 1996 F150 & Larger F-Series Trucks 1 04-08-2010 02:26 PM
Tags
2003, 2004, 2007, 2008, 4x4, bearing, bearings, f250, ford, front, grease, maintenance, needle, shasta, wheel
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
