Rear clunking sound - Ford Truck Enthusiasts Forums
Excursion - King of SUVs 2000 - 2005 Ford Excursion SPONSORED BY:
Rear clunking sound
Old 08-24-2009, 01:44 PM
mrad mrad is offline
mrad is gaining momentum as a positive member of FTE.
Rear clunking sound
I have a clunking sound coming from the rear of my X when I stop and take off. The sound does not happen until the vehicle has been driven for a few miles. After it has been driven, I will get one clunk when I stop. When I take off I will get one clunk as the vehicle starts to accelerate, and another clunk as I give it a little more gas. Any Ideas on what could be the cause of this?
I do not get the sound when I shift from park to drive, or drive to reverse.
Old 08-24-2009, 01:59 PM
UrbanXX's Avatar
UrbanXX UrbanXX is offline
UrbanXX has a superb reputationUrbanXX has a superb reputationUrbanXX has a superb reputationUrbanXX has a superb reputationUrbanXX has a superb reputationUrbanXX has a superb reputationUrbanXX has a superb reputationUrbanXX has a superb reputationUrbanXX has a superb reputationUrbanXX has a superb reputationUrbanXX has a superb reputation
The problem is:
The Slip-Yoke the rear drive shaft bolts to on the rear-end needs greased..........
The fix:
Take rear drive shaft loose from rear-end, remove slip-yoke, grease spline with a good high-temp. grease.
Reinstall Slip-Yoke and drive shaft, your good to go for another 50,000 miles or so.
Old 08-24-2009, 02:11 PM
EXv10 EXv10 is offline
EXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputation
Plus one on that.
Old 08-24-2009, 03:05 PM
Thanks guys. Is this something that should be fixed immediately to prevent damage?
Is it it possible to tap and add a grease zirt?
Old 08-24-2009, 03:23 PM
Monsta's Avatar
Monsta Monsta is offline
Monsta has a spectacular reputation.Monsta has a spectacular reputation.Monsta has a spectacular reputation.Monsta has a spectacular reputation.Monsta has a spectacular reputation.Monsta has a spectacular reputation.Monsta has a spectacular reputation.Monsta has a spectacular reputation.Monsta has a spectacular reputation.Monsta has a spectacular reputation.Monsta has a spectacular reputation.
Quote:
No. It's really just an annoyance. Too little grease from the factory or inferior grease. Once you do it you shouldn't have to do it again.
You can but it's not really with the effort and you could possibly run into balance problems...although I doubt it.
Old 08-24-2009, 03:54 PM
UrbanXX's Avatar
The sooner you get it repaired the better, it won't get any better only worse. Every time it clunks it puts stress on the U-Joint and the splines of the Slip-Yoke.
It dosen't have to be fixed tomorrow, but as soon as soon as possiable. About 75.00 from a good shop is what I would guess.
Old 08-24-2009, 04:51 PM
You could easily do it yourself in 20 minutes. I wouldn't bother with a zerk installation. You might never have the problem again as long as you have the truck. Mine had the problem when I bought mine (got me a better deal) but went away before I had a chance to fix it and that was 2 years ago. I would say it is a 1 time problem if that.
Old 08-24-2009, 06:50 PM
Just to make sure this is the slip yoke problem. Mine Does not clunk when I put it in gear. Only when I come to a stop (or near stop) and again when I take off. I hope it is the slip yoke since the fix appars to be quite easy. Thanks again for all the info.
Old 08-24-2009, 11:56 PM
Probably got lucky this time.
Old 11-26-2009, 02:21 AM
EX40 EX40 is offline
EX40 is starting off with a positive reputation.
Revisiting an old thread.
I plan on greasing the slip yoke on rear to get rid of that dreaded clunk on shifting into gear or taking off.
My question is this: Has anyone or is it typical to do the front as well? Reason I ask is I noticed the front u-joints when replacing my sway bar bushings. Seems like an easy task. I've read the article on doing the rear. Is the front the same?
Old 04-22-2012, 08:44 PM
stanfriedman stanfriedman is offline
stanfriedman is starting off with a positive reputation.
I have a 2002 F-250 extended cab with the exact same symptom. I've greased the splines twice and no permanent solution to the clunk (or two) on takeoff (or complete stop). Did greasing solve your problem?
Old 04-22-2012, 11:27 PM
timf150's Avatar
timf150 timf150 is offline
timf150 has much to be proud oftimf150 has much to be proud oftimf150 has much to be proud oftimf150 has much to be proud oftimf150 has much to be proud oftimf150 has much to be proud oftimf150 has much to be proud oftimf150 has much to be proud oftimf150 has much to be proud oftimf150 has much to be proud of
Here is a forum that talks about greasing the yoke.
http://www.ford-trucks.com/forums/10...my-2000-a.html
Tim M
Old 04-24-2012, 05:07 PM
The_Punisher's Avatar
The_Punisher The_Punisher is offline
The_Punisher is starting off with a positive reputation.
Quote:
Originally Posted by UrbanXX View Post
The problem is:
The fix:
That fixed half my noise, the other noise was due to the bumpers on the slapper bars on rear springs were gone.
Not buying it new I did not know they had been there at one time
Old 04-24-2012, 09:55 PM
Quote:
PS: Re-lubed slip yoke splines today and the clunking is gone! I know now for sure that a double clunk on takeoff and with gentle braking to a stop is due to drying out of Teflon lubricant. This time, however, I've noted the date so that I will be able to see how long this fix will last.
PPS: The splined end of the rear drive shaft in my f-250 is already factory-coated with blue Teflon, indicating that Ford has already tried to solve this recurrent problem.
Old 04-25-2012, 12:27 AM
wpnaes's Avatar
wpnaes wpnaes is offline
FTE SoCal Chapter LDR
wpnaes has a superb reputationwpnaes has a superb reputationwpnaes has a superb reputationwpnaes has a superb reputationwpnaes has a superb reputationwpnaes has a superb reputationwpnaes has a superb reputationwpnaes has a superb reputationwpnaes has a superb reputationwpnaes has a superb reputationwpnaes has a superb reputation
A few more pic's if needed and a side job or two while in the neighborhood...
http://www.ford-trucks.com/forums/10...nion-seal.html
2016 Makes Clunk at Rear End When You Hit a Bump wfoskir 1999 to 2016 Super Duty 15 01-02-2017 08:15 PM
Clunk/vibration in rear end Jfountain86 1999 - 2003 7.3L Power Stroke Diesel 14 08-05-2016 01:01 PM
Scary clunk in drivetrain DBreedlove 1999 to 2016 Super Duty 24 04-07-2014 11:49 AM
2004 Escape clunk while turning. crazn Escape & Escape Hybrid 0 04-11-2012 09:19 AM
clunk in rear end JC00EX Excursion - King of SUVs 5 09-25-2003 12:11 AM
Tags
clunk, duty, end, excursion, f150, ford, grease, problems, rear, slip, start, stop, super, tap, yoke, zerk
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
