2007 - 2014 Expedition & Navigator 2007, 2008, 2009, 2010, 2011, 2012, 2013 and 2014 Ford Expedition and Lincoln Navigator
V8 a little slugish?
Old 08-23-2009, 09:10 PM
jdm5630's Avatar
jdm5630
jdm5630 is offline
Ive noticed that my expedition is a little sluggish off the line or if i punch it going about 40 down the road. It seemed that my 2002 explorer 4.6 L had more power. Is it just because the expedition EL is a much bigger vehicle?
Old 08-23-2009, 09:13 PM
jdm5630's Avatar
jdm5630
jdm5630 is offline
i forgot to post that its a 07
Old 08-23-2009, 10:38 PM
Conanski's Avatar
Conanski
Conanski is offline
It's all about power to weight ratio, the Explorer is probably close to 1500lbs lighter than the Expedition with nearly the same amount of power under the hood.. you didnt say what engine the Expy has.
Old 08-24-2009, 12:41 AM
Tylus's Avatar
Tylus
Tylus is offline
MMNC (SS)(Ret)
your EL wieghs every bit of 6,000 lbs...and depending on what options you have, may even be closer to 7,000 lbs.
the 5.4 is a great motor, but 300 HP will only get you so much performance.
not to mention, the Transmission is adaptive. So if you drive it like a granny, then the TCM will learn that and shift accordingly. You have to reset the TCM and drive it aggressively so it learns that aggressive pattern. Not night/day difference, but you will notice a better feel
Old 08-24-2009, 10:41 AM
berry1234's Avatar
berry1234
berry1234 is offline
Having had both Explorers and Expys I would not say the 07-08 Expys are slugish. I have yet to see any unmodified Expy or Explorer make me say 'wow' but I think the latest generation is much more peppier that the older suv's.
Old 08-24-2009, 02:27 PM
seeyalater's Avatar
seeyalater
seeyalater is offline
I recently got the SCT X3 programmer and in "Performance" mode, the throttle feels a lot more responsive, specially at low Rpms/Speed. Some of that throttle lag is gone. At higher speeds, I don't know if the car feels any faster, and I still get crappy MPG.
Old 08-24-2009, 03:53 PM
nfntruth's Avatar
nfntruth
nfntruth is offline
I traded in a 4.6L 2006 explorer for the 07 5.4L XLT Expy. The Expy smokes the Explorer. You might want to get it looked at if it feels sluggish. My expy is on 33" x12.5 ATs, and it NEVER feels sluggish. Sounds like there might be a problem?
Old 08-24-2009, 04:57 PM
gddyup's Avatar
gddyup
gddyup is offline
I have an 07 Limited EL Expy and my wife has an 07 Explorer EB with the 4.6. The Expy is certainly more powerful than the Explorer but the Explorer feels more peppy due to it's much lighter weight. Between the 2, I would much, much rather be driving my Expy. I have a lot more fun with it than my wife's Explorer when I have to drive it.
Old 08-24-2009, 06:18 PM
jdm5630's Avatar
jdm5630
jdm5630 is offline
it has the 5.4L
Old 08-24-2009, 06:19 PM
jdm5630's Avatar
jdm5630
jdm5630 is offline
how do you reset the TCM?
Old 08-24-2009, 06:35 PM
berry1234's Avatar
berry1234
You can't. Unlike the PCM, unhooking the battery does not clear the TCM. Dealer has too.
Old 08-24-2009, 08:12 PM
jdm5630's Avatar
jdm5630
jdm5630 is offline
well i just had the TCM and PCM updated last tuesday because of tranny issues. Should i just drive more aggresively?
Old 08-28-2009, 09:33 AM
70BOSS 302's Avatar
70BOSS 302
70BOSS 302 is offline
I have an 07 Expedition (4X4) and it runs extremely well. It mainly sits in the garage and I drive a 2003 F150 regular cab FX4 everyday (with a 5.4) and the Expedition will run circles around it. Around 2,600 to 2,700 PRM this 3V 5.4 really, really wakes up. I can say from experience that some of the very same engine variations will run a lot better than others identical to it.
Old 08-28-2009, 10:35 AM
berry1234's Avatar
berry1234
I would drive it as you normally do. No need to stomp on it unless you like too.
Old 08-28-2009, 01:41 PM
Mustang6147's Avatar
Mustang6147
Mustang6147 is offline
That is good, They did good when they reset my truck also...
00Harleydavidson
1997-2006 Expedition & Navigator
20
11-07-2014 10:44 AM
1999 expedition
11-03-2014 01:49 PM
bayou barataria
12-22-2010 04:43 PM
Cecil Little
04-30-2007 07:07 PM
ConradX
11-05-2002 10:05 PM
Quick Reply: V8 a little slugish?
