94 2.3L Ranger- How To Replace Clutch, Slave, Etc? - Ford Truck Enthusiasts Forums
Ranger & B-Series All Ford Ranger and Mazda B-Series models
Old 08-23-2009, 02:32 PM
Critterhunter Critterhunter is offline
Critterhunter is starting off with a positive reputation.
I bought this old girl new in 94 and for the most part she's given me 275,000 miles of nearly trouble free driving. It's been sitting for the last year due to a blown original clutch and now I'm fixing to put her back on the road and shoot for the 500,000 mile mark. I've kept very good care of it mechanicly for the most part, flushing all fluids often and using synthetic for the oil, tranny fluid, gear lube, power steering fluid, etc.
Anyway, I've never done a clutch so I could use a good link with a How To on doing this. I guess I'll be replacing the clutch, pressure plate, throw out bearing, slave cylinder (heard they should be replaced when doing clutch), and any other (?) parts you guys would recommend while I'm at it. If you know of a good article or other link covering this job please shoot me a link. Thanks!
M5OD clutch slave failure modes? PineyMountainRacing Clutch, Transmission, Differential, Axle & Transfer Case 1 08-12-2015 03:51 PM
The forever question: How the heck do I get my clutch bled?? bluemtn95ford Ranger & B-Series 3 04-05-2015 06:37 PM
Finally !! Hydraulic clutch bleed squirrel64 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 3 02-26-2014 07:07 PM
95 cab and engine swap onto an 89 frame and tranny (clutch problems) Marteney 1987 - 1996 F150 & Larger F-Series Trucks 6 01-05-2014 01:33 PM
Bleeding a clutch pdqtimetrialer 1987 - 1996 F150 & Larger F-Series Trucks 14 12-28-2012 09:33 AM
Tags
1993, 23, 94, bearing, clutch, cylinder, fluid, ford, ranger, rangerhow, replace, slave, synthetic, throwout, toreplace
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
