1997-2006 Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator Discussion
Low idle/vacuum leak
Old 11-25-2002, 11:59 AM
troy221's Avatar
troy221
troy221 is offline
Hi, I have a '97 expy with a 5.4. Recently it has had a very low idle and almost stalls(chug chug). There is also a vacuum leak somewhere around the throttle body or the EGR valve but I can't pinpont it, even though it's pretty loud. That is probably causing the low idle but I cant find the leak! Has anyone else had this problem?
Old 11-25-2002, 05:40 PM
jcb67's Avatar
jcb67
jcb67 is offline
Is this noise a whistling noise?
John B.
1998 Expy 4.6
Old 11-25-2002, 06:14 PM
troy221's Avatar
troy221
troy221 is offline
It's more like a suction noise. I thought the gasket on the intake air control might be leaking,so this afternoon I took it off and cleaned it out with carb. cleaner and put gasket sealer on both sides of the gasket. My wife jumped in and took off before I had a chance to check it.
Old 11-25-2002, 07:50 PM
xtra1es's Avatar
xtra1es
xtra1es is offline
Old 11-25-2002, 09:54 PM
tsdrallyer's Avatar
tsdrallyer
tsdrallyer is offline
Hi,
On the '97 there are numerous hoses attached to the air delivery system before it enters the throttle body as well as the throttle body itself. IF you don't have a stethoscope, get a peice of tubing about 1/2 in. by 3ft long. (old garden hose works well) Stick one end to your ear, the other poke around the engine until you find the source,which will be much louder when have put the end of the tube on it.
Check also the gasket around the airflow sensor and the temperature sensor where it plugs into the side of the air tube immediately upstream of the filter cannister.
Hope this helps.
Old 11-28-2002, 10:02 AM
troy221's Avatar
troy221
troy221 is offline
Well,I found the leak. It was the hose that goes from behind the IAC to the PCV valve. The right-angle rubber boot on the hose had a big crack in it. AutoZone did'nt have the boot(or anything that would work) so I made one out of a copper plumbing elbow and two small pieces of heater hose one 3/8 and the other 5/8.Theres not much room to work with bach there and the right part would have gone on easier,but everything fit tight and it's running great now.
AlanMac
46
05-20-2013 10:36 AM
Tom Foley
1999 to 2016 Super Duty
04-17-2013 05:44 PM
mikerans
Bronco II
11-17-2012 09:31 AM
keating
06-08-2009 07:32 AM
rzuehlke
New Member Introductions
03-26-2007 12:22 PM
Quick Reply: Low idle/vacuum leak
