how do I get the best HP out of my 360/390 FE
I have a 360 FE. I already know the only difference between a 360 and a 390 is basically the crank and the carb that came stock. i already plan to rebuild my 360 . i know I want to install a 390 crank.My questions are:
#1 should I bore it out and how much?
#2 What size cam should I run?
My options are : . .256/.268---.487/.493
.270/.270---.519/.519
.262/.27--- .513/.520
.268/.268 ----.494/.494
.272/.282 ---.460.480
.280/.280 ---.530.530
.296/.296 ---.572/.572
Now bear in mind I am not Building a race truck. this is a truck that is bagged and body dropped. I just want to be able to burn the tires off for the sole purpose of looking cool. Right now it can't pull the hat off your head much less do a burn out.........
I already have a 4 barrel carb and edelbrock intake and my other plans are a set of headers.. Any other suggestions would be appreciated.. Thanks
P.S If you truly have no advice or you do not know what you are talking about please do not submit a reply thanxs
If you want it to be driveable on the street, but light 'em up quick, a mild street/strip cam would probably fit your needs best. When I get around to modding my 360, I'm not gonna go nuts with the lift, and that's why I will make the following suggestion:
Lunati Bracket Master II hydraulic
300/300---.514/.514
RPM range 1500-5000
Volumetrically, I think this duration/ lift will work very well with your dual plane setup and help to maintain your torque at lower RPM. It's one of the three cams I have been looking at for mine, with the other two being hydraulic roller cams.
Hope this helps you.
300/300---.514/.514
RPM range 1500-5000
300/300---.514/.514
RPM range 1500-5000
300/300---.514/.514
RPM range 1500-5000
thanks that helps.......
on
Bore it the minimum required to clean up the bores. It really just depends on what kind of condition your block is in, some clean up with .015 or .020, others need .030 or even more. With an engine that runs good now I would say you won't need much, but finding pistons in .015 or .020 can be tuff and that also forces people to go to .030. Out of the cams listed I would go with the third one down 268/27? .513/.520, it is close to what I had in my 68 with a 390 and it would turn the tires no sweat, but was still decent to drive. Be careful of wheel hop if you are running stock suspension.
-Johnboy
-Johnboy
223 duration on E and I at .050
112 degree lobe separation
As for the block just bore what is needed to clean it up and stay with the standard sizes of 030, 040 and 060 overbore.
Don't forget you'll need the 390 rods with the 390 crank, 360 rods will not work.
Josh
Thanks everybody for you advice.... I do know I will need to run 390 rods. What type of pistons would you guys run?
I am not running stock suspension
also i need a timing chain cover.. Does anyone offer a new one.. I can get one from a junk yard here but I am afraid it will be cracked or will crack like mine did. That aluminum is sooo brittle
I have always heard that 360 and 390 had the same rods and only the wrist pin location on the piston and the stroke was different. The chart I have only shows the 352 as having a different rod length than the other FE engines. But this does share the same stroke as a 360 so maybe I am wrong?
