84 f150 fuse box diagram - Ford Truck Enthusiasts Forums
Old 08-22-2009, 07:33 PM
driver1984 driver1984 is offline
driver1984 is starting off with a positive reputation.
i need a pic of a 1984 fuse box diagram badly! my problem is as soon as i replaced the cillonid the truck would crank 3 or 4 times then it would kept on turning over with the key out of the ing. i bypased the ing. with a push button wiring direct from battery to button from button to cillinod but i think i need to wire from fuse box to button to cillnoid if anyone could help me out i would appreciate it thanks driver 1984
Old 08-22-2009, 07:46 PM
TheKirbyMan's Avatar
TheKirbyMan TheKirbyMan is offline
TheKirbyMan has a good reputation on FTE.TheKirbyMan has a good reputation on FTE.
Make sure you didn't accidentally hook one of the little push-on connectors onto the wrong threaded post on the front of the solenoid.
And you might try sticking your key back into the ignition and turning it back toward the accessory position next time it sticks. The ignition switch inside the column might be sticking.
Old 12-06-2009, 06:54 PM
madrox madrox is offline
madrox is starting off with a positive reputation.
This is a great thing to have, I have looked and cannot find though which size fuse goes into each slot. Any one have this info?
Old 12-23-2009, 01:58 PM
ldingo ldingo is offline
ldingo is starting off with a positive reputation.
Thumbs up ??
check the voltage on the switch wire on your solenoid.
if is getting low voltage 10.5 or so or less it will cause the contacts to stick together and will keep turning the starter until 1: it runs the battery down or 2: you get perturbed and whack the heck out of the solenoid.
my low voltage was caused by a faulty neutral safety switch.
Old 12-23-2009, 07:46 PM
bghnkinf250 bghnkinf250 is offline
bghnkinf250 is gaining momentum as a positive member of FTE.bghnkinf250 is gaining momentum as a positive member of FTE.
I have the owner's manual from my 86, but I have no way to scan it to show what fuse ratings go into each slot.
Old 07-26-2011, 09:48 AM
bryan23ferra bryan23ferra is offline
bryan23ferra is starting off with a positive reputation.
Quote:
I wish my Chilton book covered this
Old 07-26-2011, 10:09 AM
ctubutis's Avatar
ctubutis ctubutis is offline
ctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputation
Old 07-26-2011, 11:28 AM
81-F-150-Explorer 81-F-150-Explorer is offline
81-F-150-Explorer is a splendid one to behold81-F-150-Explorer is a splendid one to behold81-F-150-Explorer is a splendid one to behold81-F-150-Explorer is a splendid one to behold81-F-150-Explorer is a splendid one to behold81-F-150-Explorer is a splendid one to behold81-F-150-Explorer is a splendid one to behold
Quote:
Originally Posted by TheKirbyMan View Post
You should be made aware that the above diagram is in error for the year models.
It should say 1980 only for the list to the left, and 1981-1986 for the list to the right.
Old 07-26-2011, 04:29 PM
ctubutis's Avatar
Yes, I think Franklin fixed his in his gallery sometime late last year.
Old 07-26-2011, 07:09 PM
The Haynes book I had was wrong too....not one thing was the same between the book and my actual fuse box...
Old 07-26-2011, 07:29 PM
ctubutis's Avatar
Shocking!!!!!!!
Old 07-26-2011, 09:24 PM
lol! Makes you wonder where they get their info from...
EZ-21 installation question JimG1098 1948 - 1956 F1, F100 & Larger F-Series Trucks 12 12-29-2015 07:03 PM
84 Factory radio wire colors/diagram needed CountryBumkin 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 7 09-17-2012 11:23 AM
2004 sport trac heated seats won't power off winfordr Explorer, Sport Trac, Mountaineer & Aviator 5 09-16-2011 05:10 PM
Fuse box diagram? Help please. littlepaul26 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 8 01-11-2010 06:29 PM
1984 F250 Wiring Diagram Fordattack 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 4 07-05-2008 10:27 PM
Tags
1980, 1984, 2000, 83, 84, box, diagram, f150, f250, ford, fuse, fuses, location, panel, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
