Rim bolt hole pattern
Does anyone know when Ford changed the bolt hole pattern from imperial to metric measurements ?
My truck is a 1988 so I know it was imperial then. I am shoping for some better rims and it would be
helpful to know.
Thanks
helpful to know.
Thanks
The following 2 users liked this post by Scndsin:
Received 3,106 Likes
on
on
on
To fit your truck correctly you want a '96 or older F150/Bronco wheel, the 5x135mm wheel used on some later F150s has the wrong offset so even if you did make it bolt on there would be tire rubbing issues. Some Dodge and Jeep vehicles also use the 5x5.5" bolt pattern but again I have found the wheel offset isn't ideal and in some cases the hub opening diameter is too small.
on
Russronning
10-08-2012 09:49 AM
ken04
07-15-2005 08:52 AM
