Truck stuck in 4x4 - Ford Truck Enthusiasts Forums
1999 - 2003 7.3L Power Stroke Diesel SPONSORED BY:
Truck stuck in 4x4
Old 08-22-2009, 08:02 AM
randle_ford randle_ford is offline
randle_ford is starting off with a positive reputation.
Truck stuck in 4x4
Truck appears stuck in 4x4. Moving the selector from 2WD to 4WD or 4WD Low the lights on the dash continue to say "4X4 Low". Have tried unlocking and locking the hubs to no avail. Have noticed that when I go in reverse and let off the gas the transmission seems to grab and stops the truck very quickly.
Currently i have the hubs locked (just to be safe) and 2WD selected. Engine runs fine but the ride is rough, harder turning then when not in 2WD, doesn't coast well when off the gas, etc.
Where do I start diagnosing?
Old 08-22-2009, 08:29 AM
new2diesel new2diesel is offline
new2diesel is starting off with a positive reputation.
Hi, first off, did you try to get out of 4x low in neutral. If so and you are stuck in low, I don't know how much driving I would do. I'm also assuming you have the 4x switch on the dash. If your 4x isn't dis-engaging, I would look at the solenoid on the transfer case first. If the hubs aren't dis-engaging you would have to look in the hubs to determine if they are rusted or filled with crap or you have a vacume leak. You might want to start with the solenoid.
Old 08-22-2009, 08:43 AM
triskit16's Avatar
triskit16 triskit16 is offline
triskit16 has a very good reputation on FTE.triskit16 has a very good reputation on FTE.triskit16 has a very good reputation on FTE.
Neutral with your foot on the brake
Old 08-22-2009, 08:48 AM
beanhead6D5's Avatar
beanhead6D5 beanhead6D5 is offline
beanhead6D5 is a name known to allbeanhead6D5 is a name known to allbeanhead6D5 is a name known to allbeanhead6D5 is a name known to allbeanhead6D5 is a name known to allbeanhead6D5 is a name known to all
What these guys said ^^^^^^.Thats how I have to get mine out of 4x4.
Old 08-22-2009, 12:22 PM
dmueller71's Avatar
dmueller71 dmueller71 is offline
dmueller71 is gaining momentum as a positive member of FTE.
I also once had the wire harness come loose on the transfer case solenoid. It looked like it was on all the way, but it just worked a little loose. Simple things first I always say
Old 08-22-2009, 12:33 PM
PaysonPSD's Avatar
PaysonPSD PaysonPSD is offline
PaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputation
Info on ESOF Operation. I had a problem of not engaging 4WD Low. I cleaned up the spade connectors on the ESOG relays and in would then shift into 4WD Low. May be the same problem for not shifting out of 4WD Low.
Old 08-22-2009, 01:54 PM
For the morning I kept the hubs locked and the selector on 2WD. After running a few errands (stops and starts) the truck appears now to be back in 2WD. Man I hate gremlins. I'll check the wiring and also try the neutral trick if it happens again. I doubt it is the hubs as I had them completely replaced 2 years ago. I have an early '99 truck which has different hubs then most so I replaced them so I wouldn't get stuck on the road somewhere and no one could easily get parts.
By the way, where is the solenoid harness for the 4WD? I have the big manuals but just too lazy to dig them out.
Old 08-22-2009, 04:30 PM
74baja's Avatar
74baja 74baja is offline
74baja is starting off with a positive reputation.
It sounds like if you are in neutral with your foot on the brake, your problem lies in the transfer case as well as the hubs. I have never had an issue with the transfer case, but sometimes when my hubs want to stay locked, I take the chrome covers off the hubs and give them a few taps on the sides with a hammer, and jiggle the axle ujoint a bit. Sometimes that helps free the hubs up. But, it sounds like you need to make sure you are in neutral with foot on brake.
Old 08-22-2009, 07:04 PM
dmueller71's Avatar
if the transfer case in in 2wd, it shouldn't matter if the hubs are locked or not
Old 09-06-2009, 10:13 PM
F350DS4x4 F350DS4x4 is offline
F350DS4x4 is starting off with a positive reputation.
Help...read your post
F350 4x4 1999 Super Duty.
It stuck in low 4x4 according to the lights on the dash.
I try to turn switch no reaction??
Frustrated Any Solutions. Need for work
thanks for all advice...
SO I FOOT ON BRAKE AND IN N...WORK LIKE A CHARM..KICK ***
4x4 operation questions Jimmy Dean 1999 to 2016 Super Duty 43 02-02-2014 10:25 AM
F250 4x4 operational questions Jimmy Dean Offroad & 4x4 5 01-28-2014 08:41 PM
4x4 low light flashing/ stuck in 4x4 MBVHauler 6.4L Power Stroke Diesel 3 02-11-2013 09:07 PM
03 kind of stuck in four wheel drive Pro DIY Expedition & Navigator 11 12-29-2009 05:30 PM
grinding sound in 4 wd what is it???? FordPickMeUp Clutch, Transmission, Differential, Axle & Transfer Case 3 11-18-2004 03:05 PM
Tags
1999, 4wd, 4x4, 99, case, duty, f150, f350, ford, low, manual, solenoid, stuck, super, transfer
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
