1997 Ranger, Misfire on cylinder 1
I have a 97 Ford Ranger, 2.3L, 4cyl. with 190K miles. The truck ran great until recently. I have solved the issue, so I'm posting my finding here, hopefully I can help someone in the future.
Error: Misfire on cylinder 1
Symptoms: Rought idle / erratic idle, low on power, check engine light stays on, at low speeds check engine light will flash, engine would stall periodically, runs 'fine' at highway speeds.
Solution: Loose vacuum line! I had done a visual inspection a couple weeks ago, eveything seemed fine. However, last night I went through most of the vacuum connections. Sure enough, one of the connections 'looked' fine but wasn't actually connected. It was the connection on the driver side, under the intake manifold, near the cylinder 3 spark plug. Also, check the connections on passenger side, near the firewall. I reconnected the vacuum line, disconnected/reconnected the battery. Truck runs great, issue solved. Before checking the vacuum lines I did the usual, plugs/wire/compression test/spark check/O2 sensors/fuel filter... Just wanted to let people know, check the easy (and free) stuff first, like vacuum lines. Hope someone can benefit from this in the future.
Thanks, Luke
Thanks, Luke
animator
101
01-03-2023 10:34 AM
xjcamaro89
2004 - 2008 F150
447
01-31-2022 07:35 AM
arco777
Modular V8 (4.6L, 5.4L)
13
04-22-2011 08:21 PM
