Where is the VIN? - Page 2 - Ford Truck Enthusiasts Forums
Where is the VIN?
Old 08-26-2009, 02:29 AM
NumberDummy's Avatar
NumberDummy NumberDummy is offline
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
Quote:
Originally Posted by elbert ford man View Post
I just acquired a 1935 and a 1942 farm truck. Is the VIN etched into the frame anywhere? The small metal plates that are riveted to the engine side of the firewall have been exposed to the sun for a decade or so. My '48 F-6 has the VIN on an identical plate. Trying to get the VIN so I can get them titled.
There is no VIN on any Ford truck prior to 1948, none on any Ford car prior to 1949.
These older vehicles were registered by the serial number which was also the engine number.
The problem was...if the engine was changed, the numbers would no longer match, excepting what Ford dealers were supposed to do.
When installing new engine blocks, dealers were supposed to stamp the old engine number on the new block, but not evey dealer did this.
The VIN = Vehicle Identification Number, registers the entire vehicle, not just the engine.
Old 08-26-2009, 05:08 AM
Ken Blythen's Avatar
Ken Blythen Ken Blythen is offline
Ken Blythen has a very good reputation on FTE.Ken Blythen has a very good reputation on FTE.Ken Blythen has a very good reputation on FTE.Ken Blythen has a very good reputation on FTE.
Quote:
Originally Posted by mprsox View Post
Hi, I have a 1940 ford one ton and could not find the vin on the frame rails
mprsox
I have a '41 1 ton (not mobile) - on mine the chassis no. is stamped on the top flange of the LH rail, near the front
Old 08-26-2009, 05:41 AM
huntress's Avatar
huntress huntress is offline
huntress is gaining momentum as a positive member of FTE.
Quote:
Originally Posted by 0ldV8truck View Post
Whats the number on end of the camshaft? you will have to remove the distributer I think it should b 5T
What does that number signify?
I was planning on pulling the wiring in the next couple days, I'll let you know.
Old 08-26-2009, 08:06 AM
soule46 soule46 is offline
soule46 is starting off with a positive reputation.
What Bill says is technically true, but when the state asks you for a VIN it is the "engine" number that they are looking for on these old trucks. You will not be able to get away with the argument that there is no VIN on the truck. Interestingly, since the "engine" number was stamped on the frame and put on a body tag, it does identify the entire vehicle -- the only thing it doesn't do is describe the vehicle the way more modern VINs do. Again the "engine" number was not put on the engine except in a few states that required it to be on the engine, the dealers in these states were supposed to stamp the engines when they arrived. Therefore calling it an engine number is a misnomer, it should be called the transmission number because it only truely identified the transmission.
Old 08-27-2009, 02:42 AM
0ldV8truck's Avatar
0ldV8truck 0ldV8truck is offline
0ldV8truck is starting off with a positive reputation.
I have a 47 3 tonner , the 5t is the truck camshaft High torque i think, My truck is repowered with a different block and runs a car camshaft i think it a 29AB or somthing.
Old 08-27-2009, 05:02 AM
Quote:
According to a Jan/Feb 1947 Kelley Blue Book I have, it says:
"The engine number and the serial number are the same." This applied to all the automakers vehicles, not just Ford Motor Company vehicles.
In the Ford section, it says: "The number is also stamped on the clutch housing and can be seen when the transmission cover is removed.
My 1934 and 1939 Packards have their original engines, both are registered by their specific engine numbers.
The Kelley Kar Company was...at one time...the largest used car dealer in the world (and a Ford Dealer in the 1930's/40's).
His business encompassed one entire block of Figueroa Street, which was downtown LA's original auto row.
Kelley was the one that came up with the idea of using the VIN system.
Old 08-27-2009, 08:33 AM
And this really becomes important for the very early Fords where the number was only assigned to the engine and not put on the frame at all. I don't know for sure when they started to put the number on the frame, but I am thinking about '32. It is also important to understand the difference when dealing with old cars like Chevy where they had an engine number and a different body number.
But because VIN has been in the vernacular since, as you say, the late '40s and it seems like every title needs a "VIN" I am willing to cut the newbies some slack, the engine number is for all purposes the VIN.
Old 08-27-2009, 05:54 PM
huntress's Avatar
So when I go to the BMV to register my truck and they ask for the VIN, and I respond saying my truck doesn't have a VIN it has a serial number... will you gentlemen come with me and explain the difference to them?
Old 08-27-2009, 08:04 PM
Gosh no, don't confuse them -- they usually have a hard enough time dealing with trying to title something that currently doesn't have one, they are looking for the number that you found on the bell. I would try to clean up the frame some though and see if the same number is found there. Remember if there was any problem in the past they may have swapped out the trans, probably not seeing the serial number fits and it has the BB. I would prefer to register the number on the frame if it was different. That would still give you a number to work with if you ever decide to replace the drive train.
Old 08-30-2009, 07:04 PM
huntress's Avatar
You should be able to find that number on the top of your frame as well, near the steering box.
That serial number does match the range of serials used for '42 according to the references I have.
I'm going to try to not open a can of worms...lol... but according to vanpelts, the serial number chart and the following info (also found on vanpelts) my truck would appear to be a 42. Please tell me if I'm reading it wrong.
My Serial number (on the frame and tranny bellhousing) is *BB18-6924616*
So wouldn't that be 18-6,924,616, and fall in the range below?
1942 Ford V8 - 90hp 18-6,769,036 to 18-6,925,898
"The serialization applied to trucks and commercial vehicles using these Ford engines. They may have different serial prefixes, but would be inclusive within the serial ranges shown."
<o>
</o>
Old 08-31-2009, 01:54 PM
Yes Alicia, your truck falls within the '42 range of serial numbers and it was originally the 90 HP engine "18". For what is worth based on the way Ford classified them you have a truck, the commercials were the 1/2 tons. I have not yet found anything that can confirm what the BB in the serial number means, it is my impression that it refers to the larger trucks, but I am not sure what size they started to use the BB, I was hoping someone with more info would chime in.
Old 08-31-2009, 02:57 PM
huntress's Avatar
Thank you for your help
vin help icehouse330 Ranchero & 1961 - 1967 Econoline 1 09-17-2015 06:10 AM
VIN plate question... marinesuperduty 1967 - 1972 F-100 & Larger F-Series Trucks 6 07-13-2015 08:20 AM
Vin problems... picardn 1948 - 1956 F1, F100 & Larger F-Series Trucks 70 07-02-2013 06:34 AM
Need a vin plate nytling92 1948 - 1956 F1, F100 & Larger F-Series Trucks 10 08-30-2009 10:48 AM
1955 VIN Locations kuttawa 1948 - 1956 F1, F100 & Larger F-Series Trucks 3 03-12-2004 07:55 AM
Tags
1928, 1939, 1940, antique, engine, firewall, ford, identifying, location, number, numbers, pickup, stamp, transmissions, truck, vin, vins
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
