Adv Trac Light - Ford Truck Enthusiasts Forums
1997-2006 Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator Discussion
Adv Trac Light
Old 11-16-2002, 08:25 AM
DCS 03 DCS 03 is offline
DCS 03 is starting off with a positive reputation.
Adv Trac Light
The Adv Trac light came on in our '03 Expedition (3600 miles). Message Center read Adv Trac Off. Dealer performed an IVD calibration "per SSM 1 6336" and the light is now off.
Any idea what happened? Is this a random occurrence, or should I be looking for more fixes down the road?
Thanks
Old 11-16-2002, 11:12 PM
Mattias Mattias is offline
Mattias is starting off with a positive reputation.
Adv Trac Light
My AdvanceTrac kept switching itself OFF at the end of my first week of ownership.
The dealer tried resetting the software but it finally took an "update" and it's been okay (knock on wood) ever since.
"update"?!? My Expy couldn't been more than 3-4 weeks old from the manufacturing floor when this happened? Is it Microsoft software?
Good luck.
Old 11-22-2002, 05:02 PM
mneblett mneblett is offline
mneblett is starting off with a positive reputation.
Adv Trac Light
This is interesting; another datapoint, FWIW:
Early today my wife called and said the "Check AdvanceTrak" message had appeared on her new one-week-old '03. She took it in to the dealer later in the morning.
This afternoon the shop called to say it was "fixed," and told her that they had "recalibrated" the AdvanceTrak system. They didn't tell her what was done to "recalibrate" it. In light of the "update" discussed above, I'm wondering whether they just executed a built-in calibration sequence using the original system, or flashed in an updated version. No way of knowing, I guess, without access to a computer that can read the software revision level.
She did ask the service manager why/how the system could have become out of calibration within only a week, and was told that it may have come from the factory out of calibration. I suppose that's possible, but if it's a simple software calibration, I would expect that would be a nearly impossible to screw-up factory procedure. Makes me wonder all the more whether our '03 was "recalibrated" or "upgraded."
In any event, if the problem recurs or I learn more about what was done, I'll "update" this post.
Mark
Old 11-22-2002, 06:31 PM
meridian1 meridian1 is offline
meridian1 is starting off with a positive reputation.
Adv Trac Light
More data. I have had my 03 EB since June, and early adopter. When I had a few hundred miles on it, my "check advance trac" came on. I happened to be (really) right in front of a Ford dealership and it was about 8am, so I just pulled in an got an line. A service manager chatted with me, and then with some other employees, and came back and said that the truck was so new that they were not sure they would know how to service this. But, he suggested I might want to cycle the ignition and see if the warning cleared. It did. Then I drove around his lot for a while, and it did not come back, so I left. Now, I have 12,000 miles on the truck and have never seen this happen again. I have been assuming that my Advance Trac is, therefore, working.
Old 11-29-2002, 02:37 AM
lostalien lostalien is offline
lostalien is starting off with a positive reputation.
Adv Trac Light
meridian1, I had the same thing happened to me after I actually made a couple of hard cornerings and tried to see how far I can push the truck. After it slide around for a bit the Advanctrac light came on and stayed on. I turned off the engine and started the truck again and since then I too have not seen the light come back on. Wierd???
Lostalien
03 Expy 5.4L 4x4
Waag Step Bars
www.lostalien.com
Old 11-29-2002, 05:25 PM
kitkerr kitkerr is offline
kitkerr is starting off with a positive reputation.
Post Adv Trac Light
03 Sport Trac leveling front end danmcclung Explorer, Sport Trac, Mountaineer & Aviator 0 03-17-2015 03:00 PM
2004 Navigator ADV Track Help! 4srfox 1997-2006 Expedition & Navigator 1 12-31-2014 10:56 PM
03 Sport Trac Headlight Switch maxndano Explorer, Sport Trac, Mountaineer & Aviator 4 03-31-2014 07:37 AM
06 Nav. Adv. Track issues marvinlong 1997-2006 Expedition & Navigator 2 08-09-2011 07:12 PM
Advance Trac jhva 1997-2006 Expedition & Navigator 1 06-14-2004 05:54 PM
Tags
03, 2005, adv, advance, advancetrac, advtrac, check, code, expedition, ford, light, navigator, system, trac, warning
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
