F350 V10 engine replacment
Hi,
My 2002 F350 6.8L engine is starting to blow smoke when started in the mornings. I have 181,000 miles on this truck and would like to get prepared for the day when the engine blows up. I found a 1998 6.8L engine for a good price.
Question: Will a 1998 6.8L V10 be a direct replacement for my 2002 6.8L V10? I would like to keep the 2002 exhaust manifolds and intake manifold.
<o></o>
Thanks,
<o></o>
Jeff
<o></o>
Thanks,
<o></o>
Jeff
I believe it was 1997 that the V10 came out in the E-series vans/cutaways and chassis, and the motor stayed the same through the 99 superduty; I believe they were 265hp. 2000-2004 V10's got the PI heads.
2005-up 3-valve, F-series trucks:
362 hp and 457 ft/lbs.
2000-2004 F-series trucks (Superduty):
310 HP @ 4250 rpm and 425 ft/lbs @ 3250 rpm.
1999 F-series trucks (Superduty):
275 hp and 410 ft/lbs
E-series, 1997-1999:
265 hp and unknown torque
E-series, 2000-up 2-valve motor:
305 hp and 420 ft lbs
That would be messy! The electronic engine controls are different on the 3-valve engines. The cam phasers are electronically controlled, and the fuel and ignition tables would also be different. You'd have to pull the brains as well as the engine from the donor vehicle and try and make it all work...
At 420 ft-lbs and 310 HP, the 2V engine's no slouch..
frustratedvanowner
New Member Introductions
02-14-2017 01:29 PM
joelmopar
Ford Truck Parts for Sale
04-28-2016 01:04 PM
joelmopar
03-12-2016 10:13 AM
