How do you know if your ignition control module is bad?
#32
I know it is jacking but I must answer if I know an answer
Mr. Fixit the sound you heard is commonlly known as dieseling there is nothing real wrong with it happening but it can be hard on parts so you do want to try and figure out what is going on. The most common fixes are new carb floats and choke adjustments make sure your choke is working correctly if not well then there you go and it is always a good time to rebuild your carb.
#34
on
Thank you 81-F-150....
I'll attack the problem over the next week or so (the vehicle is on an islated island)
When you say coil resistor "bypass" do you mean there should be 12 volts at the "I" terminal when you crank or should the 12 volts disappear when you turn to start.
The coil's Red/Lt. Green Wire should have 6-8 volts at run.
The Red/Lt. Green wire at the coil and the brown wire at the starter solenloid are tied in together after the ballast resistor in the harness. So the brown wire at the "I" terminal may also have 6-8 volts with the ignition switch in the on position but this is just bleed over from the Red/Lt. Green wire.
No, I got no spark when I grounded a plug against a headbolt. But, I'm not confident there was good contact - must try it again.
#35
on
RED DuraSpark CA only Ignition Module: D7AZ12A199A (Motorcraft DY204) / Obsolete
Fits: All 1977 CA V8 passenger cars // 1978 CA 302 Mustang / Fairmont/Zephyr / Granada/Monarch // 1979 302 CA LTD/Mercury Grand Marquis / Mustang/Capri / Granada/Monarch / Fairmont/Zephyr.
This module was a total POS! The module used on 1977's and on some early 1978's were defective. Ford had them on D99 = National Back Order for THREE months!
It was a FIASCO!
1000's of new and nearly new cars were parked on dealer service lots, because no one was able to get any.
I bought all the used modules I could find locally at wrecking yards, so the customers could get their cars back.
After three months, the modules became available again. The first shipments were also defective!
It took another TWO WEEKS to get modules that worked. It's no wonder that Ford mechanics refered to DuraSpark as NeverSpark!
BLUE DuraSpark Ignition Module: 1U2Z12A199AA (Motorcraft DY893) / 1U2Z-12A199-AA replaced D9VZ-12A199-A and D6AZ-12A199-A / Available from Ford.
MSRP: $130.60 // FTE sponsor Y2KFORDPARTS.COM price: $70.52.
It was a FIASCO!
Alot of experimentation went on in California, at our expence. IMO. The cars here were subjected to EEC-I, EEC-II, EEC-III etc... all very complicated worked half the time, hard to diagnose, crap. Sometimes they would break down before they left the lot. At least by the time EEC-IV came out, Ford worked out most of the kinks. Even the early 80's pickups were plagued by these weird computer systems in this state. Most mechanics don't have a clue how to work on these systems either.
#36
A little update here on our '76 with the 460... checked out the (blue grommet) Duraspark connections and found the correct signal...fast flashing of the test light at the coil. I'm beginning to get the impression this is not an ignition problem but a carb one, as USArmyTaterness says.
I have already converted to a manual choke so that should be OK.
Will check the readings as 81-F-150 suggests at the I terminal + coil and also the float in the carb next time I'm "over there".
Here are some more symptoms. After a hard start with plenty of cranking before she sprang to life (poured some fuel into the carb) she was running perfectly for about 2-3 minutes. Then she died on the road and refused to start. There were two backfires that caused a neighbour to come running out. He thought I had ended it all in dramatic style. Then she started again and ran perfectly.
Could the float be sticking and then opening/filling the bowl?
I've never touched a 4bbl carb... can I open and clean out the float chamber easily? I'll phone NAPA about a new float. Would prefer not to rebuild the carb until winter arrives and I have some time.
Thank you all for your help - you'll get me through this eventually!!!
#39
Thanks for making the point about the starter/battery. Since I got the truck, I have looked at the starter and it has a big dent in it. Would that affect why it isn't starting? I tried to start it the other day and it turned over ok and it sounded like it wanted to start, but it didn't. I am not sure if it is the battery because I bought it in February.
that 2nd battery would sometimes have enough juice in it to kick over normally.. other times it wouldnt even try or turned slowly..
personally id change that starter too just because of that big dent.. but thats just me... i dont like seeing big dents in parts that have moving mechanical parts in them...
#40
on
http://www.ifsja.org/tech/fuel/4350.html
There's a bunch of stuff attached to the air horn - might be better to pull it from the truck first before cleaning/rebuild...
Just a thought...
#42
#43
#44
#45
