1986 460 motor pictures? - Ford Truck Enthusiasts Forums
Old 08-21-2009, 02:26 PM
xirxious xirxious is offline
xirxious is starting off with a positive reputation.
Does anyone have a photo of this (carbed motor) from the front? The PO removed the smog pump and brackets and replaced it with a steel plate and some pipe. I'm not even sure what to look for to put it back right. Just the pass side is cobbled, the alt. is at an 8 deg andle or so and just plain looks like crap. i won't be putting the pump back in, but want the correct brackets. I don't know if 351 brackets are the same. Does the Haynes manual show a good picture or exploded view?
Old 08-21-2009, 03:20 PM
Sycostang67's Avatar
Sycostang67 Sycostang67 is offline
Sycostang67 has a very good reputation on FTE.Sycostang67 has a very good reputation on FTE.Sycostang67 has a very good reputation on FTE.
There are 2 brackets you could use, the 85-86 460's had dual smog pumps like this.
Before that they only had 1 smog pump. This pic just has the bracket with no pump.
You can use either bracket as both will hold the alt. The only other difference is the single pump bracket has a hole for the heater hose to pass through while the other bracket used a metal section of hose but I am sure you could find a way around that if you dont currently have it.
Old 08-21-2009, 09:33 PM
Homemade's Avatar
Homemade Homemade is offline
Homemade is starting off with a positive reputation.
If you still need some let me know I think mine is still all stock.
And I could try to get you some.
Old 08-21-2009, 10:58 PM
ArdWrknTrk ArdWrknTrk is offline
pedant
ArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputation
I don't know if any of these will help.
The black metal pipe that mounts to the front of the passenger side head starting from the red sealant at 10:00 on the water pump:
The bracketry sitting on the floor:
A view of the A.I.R. pumps on the engine:
Dana 60 Rear Disc Confusion!!! KsHighboy 1967 - 1972 F-100 & Larger F-Series Trucks 14 03-20-2016 09:44 AM
In search of Air Pump Adjustment and pulley Pete Kildow Large Truck 10 09-27-2013 05:46 PM
95 F-150 Saginaw p/s conversion: Bracket problem macintyremustang 1987 - 1996 F150 & Larger F-Series Trucks 17 05-13-2013 10:32 AM
77 highboy 460 swap questions jfaber 1973 - 1979 F-100 & Larger F-Series Trucks 5 01-05-2010 03:16 PM
86 f-150 slave cylinder bracket? RandysF150 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 3 12-21-2009 07:58 AM
Tags
1986, 350, 460, bracket, diagrams, engine, exploded, ford, motor, photos, pictures, pump, smog, truck, view
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
