S. California Chapter Join Chapter, Leader:
What Are You Doing To Your Truck?
Old 12-17-2014, 06:26 PM
ChaseTruck754's Avatar
ChaseTruck754
ChaseTruck754 is offline
It's like arts & crafts going on over here. Well, at least for a little while when the sun came out between the rain downpours the last few days...
Intercooler painted black because I've learned they dissipate heat better this way (at least at a stop - they flow the same while moving/with air flowing through).
Decided to get a little creative on the front side since it will show a little bit...
Arts & crafts time at night after the kiddo is asleep.
Taped up
A bit of paint
And you get this! Should look kinda cool peeking out from behind the grill
  #1487
Old 12-17-2014, 06:38 PM
orng1's Avatar
orng1
orng1 is offline
Nice detail there.
  #1488
Old 12-23-2014, 10:50 PM
wpnaes's Avatar
wpnaes
wpnaes is offline
Pinion seal giving me challenges. Shocks are done on this '65.
  #1489
Old 12-23-2014, 11:04 PM
OldBlackCat's Avatar
OldBlackCat
OldBlackCat is offline
cannot get the nut to break loose sean?
if you need a hand i got some tools that might help....
  #1490
Old 12-24-2014, 12:20 AM
SpringerPop's Avatar
SpringerPop
SpringerPop is offline
Who does that belong to? Old iron here in California refuses to die!
Pop
  #1491
Old 12-24-2014, 12:42 AM
OldBlackCat
Pop
as far as im aware its is his trusty dusty and slightly oily camping trailer!
but as cantankerous as old iron can be, he might need a little more brute force than his breaker bar and looks to be brass cheater pipe can dole out...
  #1492
Old 12-24-2014, 12:55 AM
SpringerPop
Something like a 3/4-inch impact?
Pop
  #1493
Old 12-24-2014, 01:09 AM
OldBlackCat
Pop
that might just do the trick! 1" maybe if your feeling like channeling your inner Tim Allen!
  #1494
Old 12-24-2014, 09:57 AM
SpringerPop
Do you own a one-inch impact, or does your dad?!?!
It's a pretty-unusual tool to "just have laying around", but indispensable for some things.
To a lesser-degree, the same could be said for a 3/4-inch one.
Pop
  #1495
Old 12-24-2014, 10:13 AM
bpounds's Avatar
bpounds
bpounds is online now
Are you sure you are turning it the correct way? Could be LH threads.
  #1496
Old 12-24-2014, 11:15 AM
wpnaes's Avatar
wpnaes
wpnaes is offline
Yes, it's off my Half '75 dent side F250 short bed trailer sitting on a '65 F250 chassis.
I have a cheap HF 3/8 inch impact- will check righty loosey Bill.
  #1497
Old 12-24-2014, 01:44 PM
OldBlackCat
Pop
dads got 3/4" and 1" guns ..... he had a 1" long anvil for changing truck tires but its since been sold.
they were in regular service years ago! but in there semi retirement they are "just laying around"
  #1498
Old 12-24-2014, 04:38 PM
wpnaes's Avatar
wpnaes
wpnaes is offline
The 1/2 inch HF impact and a 32 mm socket got it done. New seal in place, holding oil thus far...
Thx Justin for the call- much appreciated.
  #1499
Old 12-24-2014, 04:39 PM
wpnaes's Avatar
wpnaes
wpnaes is offline
Nut off. Penetrating oil overnight probably helped...
Ended up being lefty loosey. Couldn't tell easily looking at the threads.
I doubt I could even lift a 1inch impact wrench in place on my back!
  #1500
Old 12-24-2014, 05:00 PM
01Offroadf150's Avatar
01Offroadf150
01Offroadf150 is offline
Original Battery in 01 5.4 with 365kms
hey guys new to the site
i have an 01 f150 5.4 triton lariat with 365,000kms on her now
my brother bought it brand new so i am the second owner
where im from its a bit cold this time of year
so i had to replace the battery, i took one out of my dads 05 6.0L because he got two new Ford Batteries and i put in the interstate mega tron plus.
But i just found out that it was the original motorcraft battery as my brother never changed it since hes had it.
anyways thought id share that story with y'all
lookin to do a 6' lift in the spring and 33s
Quick Reply: What Are You Doing To Your Truck?
