S. California Chapter Join Chapter, Leader:
What Are You Doing To Your Truck?
Old 09-03-2016, 09:49 PM
Big_Texxan's Avatar
Big_Texxan
Big_Texxan is offline
Well I have some good news. Quit my job, moving to Texas this week, my Ford, after all the up hill battles, finally fired, ran, and sounds mean as ****. Truck has some serious *****, took it out for the first voyage today. Tomorrow Ill run it a little harder to see if any issues arise but I dont think they will since it idled for an hour Friday, and 30 minutes Thursday, and today almost all day collectively.
  #1787
Old 12-29-2016, 10:45 PM
Yama4fitty's Avatar
Yama4fitty
Yama4fitty is offline
Purchased my rig and did a few things to improve the looks and functionality.
- It came with some nasty painted black bumpers so I had those LineX'd with the bed and the outer grille shell. Rear still has BU sensors.
- Installed a bed bar for my dirt bikes that I use more as a tie down rack.
- Installed one of those tailgate assist things to drop it with one hand.
- Upgraded OEM dash unit to a Pioneer DVD/CD bluetooth and all that.
- Added a small powered sub beneath the rear seat.
- Installed 20" LED light bar where my fogs were missing.
- Installed LED lights under rear of truck to assist at night with trailer hook up. Don't help in backing so will be changing these to a bumper surface mount.
- Added a rearview camera license plate frame.
- Added a 7" monitor to sunvisor to wirelessly connect to rearview camera on trailer...work in progress
- Installed under bed rail LED lights with waterproof switch in bed.
- Installing RAM mount at A-pillar mounting location for 7" tablet to monitor Torque App PID's
- Replaced a couple injectors, GPCM, ICP, cleaned EGR, resealed other injectors, cleaned sensors......
- TO DO.....high temp stat, coolant filter set up, battery cable upgrade (being shipped), and some other things I can't think of right now
  #1788
Old 12-30-2016, 03:39 AM
OldBlackCat's Avatar
OldBlackCat
OldBlackCat is offline
quite the mod list there!
  #1789
Old 06-17-2017, 08:22 PM
wpnaes's Avatar
wpnaes
wpnaes is offline
Got this idea from BP a while back. My daily driver hit 200k and it's time.
Sure is easier compared to the 10 banger.
  #1790
Old 06-28-2017, 10:05 PM
wpnaes's Avatar
wpnaes
wpnaes is offline
  #1791
Old 06-29-2017, 10:39 AM
bpounds's Avatar
bpounds
bpounds is offline
Ford has a special grease for that slip spline. I just used regular grease in mine too. Now a few years later, it is doing that slip-stick polka again. I suppose it would have eventually anyway.
  #1792
Old 07-21-2017, 06:35 PM
husker's Avatar
husker
husker is offline
Just go grab what you need. Jamie can get you into the garage. Just call her. Text me if you need her number. Man, I wish I could be two places at once and go along.
  #1793
Old 07-21-2017, 11:20 PM
Big_Texxan's Avatar
Big_Texxan
well, moved to texas, my Ford looks like this. Ready for body work. Bought another truck, lost my chick, reclaimed some property, moved to a new place.
Picture is from my garage, on my property
  #1794
Old 07-25-2017, 12:20 AM
wpnaes's Avatar
wpnaes
wpnaes is offline
Talk about 'round tuit', I got these gauges in 2011...finally installing.
Reading the odo, maybe it's too late to monitor temps?
Would be nice to have exterior temp too...
  #1795
Old 07-25-2017, 09:25 AM
bpounds's Avatar
bpounds
bpounds is offline
3 gauge pod - what temps do you plan to monitor?
Can't quite tell what's going on with that gauge in the first pic.
  #1796
Old 07-25-2017, 09:55 AM
John Howbowtit's Avatar
John Howbowtit
John Howbowtit is offline
got 2 Hadley bullys 1 works both horns are good ,trying to figure the sound if I use all same size horns bigger or smaller and how they would sound ? neighbors r ready to call police now on me!
  #1797
Old 07-25-2017, 09:56 AM
John Howbowtit
please help
please help
  #1798
Old 07-25-2017, 10:03 AM
wpnaes's Avatar
wpnaes
wpnaes is offline
Tranny, oil, rear diff. The lower gauge/switch is the Viair onboard compressor I installed in 2010. Once I had the 3 gauges installed and working, the compressor stopped working. I need to track down the wire I disturbed.
Originally Posted by John Howbowtit
please help
Hadley bullets, I had to google that one John. Heard from a mile away! Neighbors will be on alert .
  #1799
Old 07-25-2017, 10:45 AM
bpounds's Avatar
bpounds
bpounds is offline
please help
This should appease the neighbors.
I once stuffed steel wool down the throat of a horn we had at work, which we thought was too loud. Worked pretty good to knock the sound down. Other than that, I'm not sure what the question is. You either want a loud horn, and damned the neighbors, or you get a stock horn.
  #1800
Old 07-25-2017, 11:09 AM
wpnaes's Avatar
wpnaes
wpnaes is offline
There are plenty of youtube prank videos with air horns. I hope that's not your goal John.
Quick Reply: What Are You Doing To Your Truck?
