Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Ford V6 > 3.8 & 4.2L V6
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 08-21-2009, 01:08 PM
Shefferz Shefferz is offline
Shefferz is starting off with a positive reputation.
SecuriLock Theft System Woln't let me Start Truck
Situation: 99 Ford Ranger XLT 2wd 3.0 V6
Problem: SeccuriLock/PATS anti theft system is engaged and Can’t start vehicle.
Pats Info: Ford PATS
I was installing an amp for a subwoofer yesterday. I needed to get 12v for the remote on the AMP (For those who don’t know I just need 12v to act as an on/off switch for my amp, so It’s not getting power once the vehicle is off). I chose to splice into a while on the back of the factory radio which gives 12v with the ignition switch. It was perfect because my amp would turn on/off with the ignition. I unplugged the radio from its harness and spliced the wire and ran it to the amp.
After I hooked up the amp and the subwoofer everything worked fine. Radio/lights.. the whole 9 yards. But when I went to leave the garage , the car would turn over and want to start, but would’t catch. I know it’s a problem with the PATS Securilock system because the “Theft” light its blinking rapidly. I know all about the chip in the key and the PATS module. Sooo…
I went to a locksmith today and they came out to the car because they said when you unplugged the radio it gets the PATS system out of SYNC with each other. So they made a new key and ran some other test with their scan tool and the car will still not run. He said there is no problem between the ignition (where the key inserts) and the module but maybe from the module to the PCM? I have a feeling the system just needs to be disengaged, but I can’t find any information at all. Anyone have anything?
So since the PATS theft system is engaged, how do you disengage it.. I really don’t want to take it to the DEALER.
  #2 (permalink)
Old 08-21-2009, 03:22 PM
BrianA's Avatar
BrianA BrianA is offline
BrianA has a great reputation on FTE. BrianA has a great reputation on FTE. BrianA has a great reputation on FTE. BrianA has a great reputation on FTE.
Wish I could give specifics on the PATS, but I can't.
I have unplugged the radios and replaced them on 3 different ford trucks and never had a problem. Not to second guess the guy, but I am second guessing him.
I know exactly what you are talking about re: the switched 12 volts for the amp. I recently installed an amp and subwoofer in my son's Explorer. I seem to remember a switched hot wire available in the harness available for this purpose?
I wonder if splicing has lead to your problem?
If it were me, I'd put everything back EXACTLY to factory conditions and see if the problem clears.
Maybe then look at a different approach to hooking up for power.
__________________
Brian A
If it ain't broke, don't fix it.
FTE Moderator - 3.8 / 4.2 forum
  #3 (permalink)
Old 08-21-2009, 05:07 PM
Well, I finally broke down and sent it off to the dealer today. I don't have any more time to mess around with it. I have called countless Tech's/dealers/webforum/internet search. Seems this PAT system is as elusive as Snipe Hunting. I just hope they don't pull the, " your transponder is bad 1000$ please" card. But whats a guy going to do. I need a vehicle.
Thanks for the response.
Tags
1999 , 99ford , coded , disengage , explorer , ford , key , problem , problems , securilock , securilockpat , start , system , theft , truck , trucks
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
