Truck engine vs car engine - Ford Truck Enthusiasts Forums
Old 08-21-2009, 07:46 AM
60F100 60F100 is offline
60F100 is starting off with a positive reputation.
I know this has been answered before but I can't find it. I understand that the basic difference between a car and truck engine is the cam. What is the difference and which is better for mileage with an AOD and 3.55 diff. I currently have a car 5.0 in my 90F150, is it worth the bother to change the cam? I also have a low mileage 351W that I am cinsidering swapping in but have no idea what cam is in it. It is an F0AE block. I do very little towing.
Old 08-21-2009, 02:52 PM
85e150six4mtod 85e150six4mtod is offline
85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation
If you are satisfied with the way it runs, leave it alone. Usually, "truck cams" focus on off-idle and low rev power, and sign off after 4000 rpm or so, some earlier.
Mileage wouldn't be drastically changed.
Old 08-22-2009, 04:17 PM
Conanski's Avatar
Conanski Conanski is offline
Conanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud of
Quote:
Originally Posted by 60F100 View Post
I understand that the basic difference between a car and truck engine is the cam. What is the difference and which is better for mileage with an AOD and 3.55 diff..
What car engine are you talking here, the passenger car 5.0 or the Mustang 5.0?
I currently have a car 5.0 in my 90F150, is it worth the bother to change the cam? .
Unless it's the Mustang HO motor then yes... absolutely.
A stock 5.8 of this vintage would burn more gas but not deliver a lot more power, but upgrade the cam and it would be a FAR better truck motor than any 5.0.. regardless what cam it has. It will be a little harder on gas than the 5.0 around town but better on the highway simply because it won't downshift on anything but really big hills.
Old 08-22-2009, 07:47 PM
Freaksh0w's Avatar
Freaksh0w Freaksh0w is offline
Freaksh0w is starting off with a positive reputation.
Yeah, since you already have a 351w... if you are thinking of upgrading the cam because you want some more downlow torque, or more power to pull trailers... go ahead and bypass upgrading your cam and just swap in the 351w.
302/5.0 Recommendations banjopicker66 Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 3 02-22-2015 10:33 AM
302/5.0 and Transmission Swap banjopicker66 Clutch, Transmission, Differential, Axle & Transfer Case 2 02-22-2015 06:48 AM
Help with cam selection on engine. fuelie74 1987 - 1996 F150 & Larger F-Series Trucks 3 02-23-2014 10:41 PM
Best carb and intake for a 1992 mercury 302? SPARTAN2235 Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 8 04-28-2011 03:06 PM
Cam suggestions 95 f150 93f250tn 1987 - 1996 F150 & Larger F-Series Trucks 20 02-01-2011 06:47 AM
Tags
302, 5, 58, block, cams, car, difference, engine, engines, ford, intake, motor, mustang, truck, upgrading
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
