Can a 460 use a 390 flywheel?
Much depends on the year of 460 you are working on.
Try these links:
Post #10 is pretty good.
https://www.ford-trucks.com/forums/6...heel-swap.html
Post #7 here is pretty imfornative:
https://www.ford-trucks.com/forums/3...questions.html
Easier to post the link than it is to type the entire explaination.
Do make sure that you have the internal and external balance deal under control.
Any reason why you dont just run a 385 series flywheel? They are not expensive.
Try these links:
There is no such thing as an "externally balanced 390". All 390 engines were internally balanced (AKA a neutrally balanced flywheel).
So your putting in a 460 engine where a 390 was, right, & want to use the flexplate thats already on the T/C on the transmission like it sits.
Or, your going to a clutch & straight drive transmission & need the big flywheel.
If your going the straight drive route & not going to use that 460 flexplate & its not busted up in the middle or bend, I know somebody might be interested in the flexplate.
Neil
Neil
tdmoparguy
06-29-2017 02:08 PM
billy1962
23
03-19-2012 05:17 PM
MR_J_DAHMER
11-29-2005 12:16 PM
jackslater
05-10-2005 11:01 PM
alwaysfords
11-19-2000 08:07 AM
