A/C compressor not turning on? - Ford Truck Enthusiasts Forums
Old 08-20-2009, 07:49 PM
Brown Falcon's Avatar
Brown Falcon Brown Falcon is offline
Brown Falcon has much to be proud ofBrown Falcon has much to be proud ofBrown Falcon has much to be proud ofBrown Falcon has much to be proud ofBrown Falcon has much to be proud ofBrown Falcon has much to be proud ofBrown Falcon has much to be proud ofBrown Falcon has much to be proud ofBrown Falcon has much to be proud of
When I bought my truck the previous owner said that the A/C needed to be recharged but worked.
I went to turn it on the other day and the compressor isn't even turning on at all...
Any ideas? I checked fuses and all the plugs are seated...
Old 08-20-2009, 08:25 PM
JAFO1's Avatar
JAFO1 JAFO1 is offline
JAFO1 is gaining momentum as a positive member of FTE.
Did you charge it? If not it's probably low. Pull the low refrigerant sensor off the drier and make a jumper for the plug. If the compressor cycles, you are probably low on frig'nt. If you charged it, it could be over charged.
Old 08-20-2009, 08:31 PM
73cntry's Avatar
73cntry 73cntry is offline
73cntry is starting off with a positive reputation.
I know mine started smoking when turned on. If you checked all the fuses and the wiring going to it then like JAFO1 mentioned check the above.
Old 08-20-2009, 09:11 PM
Epd444's Avatar
Epd444 Epd444 is offline
Epd444 is starting off with a positive reputation.
Like stated above, probably open on the low pressure switch. Jump it out see if compressor engages
Old 08-20-2009, 09:43 PM
johnstoys2's Avatar
johnstoys2 johnstoys2 is offline
johnstoys2 is starting off with a positive reputation.
When the charge is just low you will normaly see the clutch cycle off & on, unless it is pretty much dead empty. jumping the switch is a good quick test off the electrical system. if the clutch kicks on, the switch is bad or system is empty. if nothing kicks on, it's time to get electrical. if you find the system is empty, I would suggest vacuuming the system out unless you are just checking for leaks. just pumping freon in will limit the preformance.
Old 08-21-2009, 10:50 AM
Where is the switch I need to jump? I havn't worked on A/C EVER! I havn't done anything to it since I bought it and the clutch doesn't turn on at all...
Old 08-21-2009, 12:03 PM
johnstoys2's Avatar
the switch on the accumulator r/s of engine bay.
Old 08-21-2009, 05:29 PM
B Big's Avatar
B Big B Big is offline
B Big is starting off with a positive reputation.
When your A/C is low its because it has leaked down. (thank you Mr. obvious ). You will need to fix it. There are no short cuts.
Best wishes!
B
Old 08-21-2009, 05:51 PM
Copedawg's Avatar
Copedawg Copedawg is offline
Copedawg has a brilliant futureCopedawg has a brilliant futureCopedawg has a brilliant futureCopedawg has a brilliant futureCopedawg has a brilliant futureCopedawg has a brilliant futureCopedawg has a brilliant futureCopedawg has a brilliant futureCopedawg has a brilliant futureCopedawg has a brilliant futureCopedawg has a brilliant future
is there a way to check if the compressor is locked? Can you turn it?
Old 08-21-2009, 06:29 PM
johnstoys2's Avatar
you should be able to move the front of the clutch (flat plate in front of pulley ) by hand at the least or with a wrench at the most. if it won't turn at all it may mean a locked up compressor.
Old 08-22-2009, 10:04 PM
RubberDuck's Avatar
RubberDuck RubberDuck is offline
RubberDuck is a name known to allRubberDuck is a name known to allRubberDuck is a name known to allRubberDuck is a name known to allRubberDuck is a name known to allRubberDuck is a name known to all
One more thing to think about before you call it low on coolant. The connector on top of the a/c compressor at the rear. It's a round 2 pin connector. That is a high fail part. Turn the a/c on max, high fan. Go out and wiggle the crap out of that connector. I bet your compressor will kick on.
If it does, the connection just needs to be cleaned and tightened up. You could take a chance and crimp the female connectors a tad, and hope for the best, you could replace the connector.
I just took the red lock out of the face of the connector, took a few 3/4 inch long strands of wire, bent them in a U shape, and put them in the female end hanging half in and out of the connector. Then reinstall the lock and it will hold the copper strands in place. That one strand of copper will make all the difference in the world, and you shouldn't have any more connection problem. Hope that helps.
Old 08-22-2009, 10:30 PM
bodabdan's Avatar
bodabdan bodabdan is offline
bodabdan has a good reputation on FTE.bodabdan has a good reputation on FTE.
Also if the compressor comes on while the low pressure switch is jumpered, don't leave the jumper wire in. It is protecting the compressor because you are low on Freon. No problem to use the jumper for troubleshooting purposes though.
Old 08-23-2009, 09:45 AM
Thanks for the help guys... It's been raining so I havn't been able to work on it yet.
Old 08-23-2009, 02:46 PM
884x4broncoII 884x4broncoII is offline
884x4broncoII is starting off with a positive reputation.
i dont mean to hijack your thread but i used this one to diagnose my own ac system that worked last summer but come spring it wasn't working, i jumped the low preasure sensor ac compressor kicked on so i bought some r134a and charged it to 45 psi now the ac works but it doen't seem as cold as it should be. if i bump the idle up to 1000-1500 the preasure drops down lower, my question is what psi should our systems be charged to?
Old 08-23-2009, 04:39 PM
Epd444's Avatar
Quote:
It goes by weight to determine the charge. Theres a sticker under the hood that says the refrigerant (r134a) and then it will say the weight.
I don't know the weight off hand
locked up a/c compressor not letting motor turn over memphis_made 1997 - 2003 F150 6 11-19-2015 04:38 PM
a/c bit the big one 69issofine Ranger & B-Series 6 05-02-2015 07:19 PM
A/C Compressor Cycling Problem emueller 1999 to 2016 Super Duty 9 01-22-2011 01:50 PM
A/C compressor clutch engages and disengages. SmittyGa 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 10 08-27-2008 08:29 PM
A/C problem compressor wont stop. Aerocook Aerostar 17 07-10-2008 10:58 AM
Tags
2000, 2002, 73, 94, ac, air, coming, compressor, conditioner, f150, f350, ford, idi, power, ranger, turning, working
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
