More Help On Tranny Fuse blowing.
Hey all I posted earlier about the tranny in my 01 Ex v10 having a transmission problem. The show looked at it and found the O2 sensor had shorted out and in some way sending the truck in to limp home causing the tranny fuse to blow????
Anyway they fixed it or so they said and I drove it for a few hours and it did fine. The next morning I drove it and it blew the fuse. (under hood box I belive #19) I took it back to the shop and they beat and banged on it....got it wet etc. and can not get it to do it again. I know whe have an electrical issue but what all runs off of the fuse that controlls the tranny?
Is there any online wiring diagrams of excursions or superduty drive trains? Do you have any ideas of where all to look for the problem????
Thanks
Brian Felts
Thanks
Brian Felts
Guys, take the plastic surround off your steering column and check for worn or exposed wires coming from the Overdrive switch. This is famous for creating many different "symptoms", blown fuses especially. And the worn or exposed wiring is happening to a very large number of Excursions nationwide.
Here's a picture in a thread about the problem....
https://www.ford-trucks.com/forums/7...uestion-3.html
Thanks VASheriff
Took care of the O/D wire not to long ago as it was causing a blown fuse in the fuse box under steering wheel, fuse 19.
Now this is a different problem. The 19 fuse, 25Amp, under the hood blows everytime I power up the car, don't even have to crank the engine. Since it pops before I start, and is the fuse for the tranny, suspect the tranny's crap performance is due to the disrupted circuit. No idea what to do next.....appreciate the advice on the worn O/D wire as I have been a victim too.
Aaron 77
Aaron 77
Colton92
1997-2006 Expedition & Navigator
11-23-2016 06:51 PM
Big Bend Brian
03-28-2010 12:20 AM
