1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Rear differential capacity
Old 08-20-2009, 04:23 PM
bryanj's Avatar
bryanj
bryanj is offline
So I bought the early 99 F350 7.3l dually I was asking questions about a couple of weeks ago. I get the shutter in the rear differential on slow turns, so I'm off to change the fluid. I didn't get any owners manuals with the truck, so I have no idea what the capacity is. The VIN sticker says the axle is an "F2". I'm a bit torn about which route to take; should I do the standard gear oil then add the friction modifiers or should I just go the royal purple route? What are some other options? I don't want to spend a fortune on gear oil just to find out that I need to replace the clutch packs. The truck has 22K miles on it, but didn't move much in the last 5-6 years, so I suspect the clutch packs are fine.
Any thoughts and what is the capacity? Thanks for the help....
Bryan
Old 08-20-2009, 05:15 PM
cbradford's Avatar
cbradford
cbradford is offline
F2 — 4.10 limited slip, F-350 (dual rear wheels) and I'm thinking 2qt's of Ford synthetic 75w140 weight gear lube and 1- 4oz bottle friction modifier, or 2qt's + Royal Purple for limited slip, but you may want to call your local Ford Dealer for the recommended quantity. I used the Ford Lube myself but it's a personal choice.
Old 08-20-2009, 07:46 PM
06silvercrew's Avatar
06silvercrew
06silvercrew is offline
A dana 80 takes alot more then 2 quarts. I just done one last weekend, took just over 4 quarts plus the additive.
Old 10-04-2010, 10:30 AM
hitekhomeless's Avatar
hitekhomeless
hitekhomeless is offline
I also have axle code: F2 — 4.10 limited slip, F-350 on my 2001 4x4 Dually. Is 75w140 the correct weight? Will it take just over 4 quarts? What about the front end? How do I find out?
Thanks in advance!
Old 10-05-2010, 10:20 PM
hitekhomeless
Talking
Sorry for the necro posting, but hey, at least I used search
higgins909
2004 - 2008 F150
06-23-2017 02:36 PM
Mikef600
Large Truck
13
10-21-2016 08:29 PM
rogerranger2122
1983 - 2012 Ranger & B-Series
10-03-2016 09:22 PM
dog2580
1997 - 2003 F150
01-29-2012 10:45 AM
SteevenH
1997 - 2003 F150
03-21-2010 08:49 PM
Quick Reply: Rear differential capacity
