Part number needed for exhaust manifold studs and question
What is the part number for the "better" stainless studs from Ford. My local dealer only shows the standard steel replacements for about a buck each. I think i have seen the better ones are $7 or $8 each. Are they worth the extra $$. Any other sources for a quality replacement.
If you can find them, super. But usually exhaust studs have coarse threads going into the head, and fine threads on the outside. It certainly would be cheaper. The Ford stainless studs were expensive!
