Go Back   Ford Truck Enthusiasts Forums > Other Fords > Ranchero and 1961 - 1967 Econoline
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 08-20-2009, 02:38 PM
flatheadjohn flatheadjohn is offline
flatheadjohn is starting off with a positive reputation.
Windshield Installation
Does anyone have detailed instructions on how to install a windshield on a 65 Ford Ranchero. I'm having difficulties and the instructions that were included with the new windshield rubber are vague and not very helpful. This windshield uses the stainless trim around it to essentially "lock" the windshield in place. The whole is a bitch trying to keep all the stainless on and the rubber gasket around the windshield on all at the same time. A guy needs at least eight hands! Any help would be appreciated.
  #2 (permalink)
Old 08-20-2009, 07:44 PM
Bill W's Avatar
Bill W Bill W is online now
<<< under construction
1966 Ford F-100
My Garage
Bill W has much to be proud of Bill W has much to be proud of Bill W has much to be proud of Bill W has much to be proud of Bill W has much to be proud of Bill W has much to be proud of Bill W has much to be proud of Bill W has much to be proud of
I just had the windshield replaced in my 66 f100 (has the trim around it)
the guy used masking tape to hold it in place untill they got it set in the frame.
They put the gasket on the window first then installed the trim.
Hope that gives you some ideas.
__________________
My Truck- Here!
Join AZ Chapter Here!
  #3 (permalink)
Old 08-21-2009, 11:06 AM
Thanks for the advice I appreciate it and maybe I'll give that a try, or just pay someone to do it before I break something!
  #4 (permalink)
Old 08-22-2009, 12:21 AM
66gpw's Avatar
66gpw 66gpw is offline
66gpw is gaining momentum as a positive member of FTE. 66gpw is gaining momentum as a positive member of FTE.
That is a good idea to tape the chrome in place before you set the windsheild back. Once it is in the frame the rubber should squeeze tight to keep the chrome in.
I use soft ropes to put windsheilds in. Lube then up with soapy water adn set the bottm of the glass in and slowly pull the rope out over the frame. This will pull the rubber lip over the frame lip. The soap acts as a lubricant making it easir.
You start pulling the rope out from the bottom edge and work your way around to the top center. The corners can be tricky.
But the tape to help hold the chrome trim in place is a good idea.
__________________
64 Econoline Truck.
67 Econoline truck
85 F150 Explorer XL
86 F150 Exploere XLT Ext cab
66 Merc 1Ton Flat deck
78 F250
  #5 (permalink)
Old 08-22-2009, 12:26 AM
Bill W's Avatar
1966 Ford F-100
My Garage
You need two people, one to pull the rope and one to push the window from the outside into place.
when the shop did mine they slaped the windshield into place with an open hand.
__________________
My Truck- Here!
  #6 (permalink)
Old 08-22-2009, 12:55 AM
66gpw's Avatar
Done that and next had bunch of cracks. They have to slap along the edge. If they hit away thatis when you can crack it.
Two people is better than alone. But I have installed my Econoline truck windsheild by myself. Still in the truck with no cracks.
__________________
64 Econoline Truck.
67 Econoline truck
85 F150 Explorer XL
78 F250
Tags
150 , 1965 , 55 , 86 , f100 , f150 , ford , install , installation , installing , intall , truck , window , windsheid , windsheild , windshield
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
