Dead Dash - Ford Truck Enthusiasts Forums
2007 - 2014 Expedition & Navigator 2007, 2008, 2009, 2010, 2011, 2012, 2013 and 2014 Ford Expedition and Lincoln Navigator
Dead Dash
Old 08-20-2009, 09:34 AM
namrehs300 namrehs300 is offline
namrehs300 is starting off with a positive reputation.
Dead Dash
My 07 Expy Limited with NAV has a dash that goes dead. Everything on the dash goes dead - lights out, radio out, A/C stops working. Cure is to pull over and turn off the truck and then back on.
Seems to be worse during very hot weather. It is a Ford problem (had this on my F250 and I was in my friend's F250 last week and it went dead). Didn't see a thread on this here. Anyone have this problem? What did the dealer do to fix?
Old 08-20-2009, 10:02 AM
hookd's Avatar
hookd hookd is offline
hookd is starting off with a positive reputation.
never had this happen but I bet it scared the crap out of you when it happened the first time
Old 08-20-2009, 11:45 AM
berry1234's Avatar
berry1234 berry1234 is offline
berry1234 is gaining momentum as a positive member of FTE.
I would pull all the fuses and relays and put back one at a time. Sounds like a bad circuit board though. I would post a Q on flateratetech.com in the Ford section.
Old 09-07-2009, 12:10 AM
JamesDuffer JamesDuffer is offline
JamesDuffer is starting off with a positive reputation.
It happened to me this weekend on my 2000 Expedition. Now when I shut the engine off. Tried to start it 30 min later, and it acted like a dead or very low battery. With a power boost it started, voltage gage went to mid scale and shortly thereafter, the red battery warning symbol came on. according to owners manual this indicates a problem with the battery or battery chargeing system. Today it started o.k, but red battery indicator remains on, yet gage shows normal reading for battery. Am perplexed, and awaiting to find out what happened with previous postings.
Old 09-08-2009, 02:19 PM
berry1234's Avatar
Found this. May or may not apply.
Printable View (70 KB)
TSB
07-7-4 MESSAGE CENTER SWITCHES INOP-TEXT BLANK/SCRAMBLED/COMPASS INOP/WASHER LIGHT ON/OAT READS HIGH
Publication Date: March 27, 2007
FORD: 2007 Expedition
LINCOLN: 2007 Navigator
ISSUE:
Some 2007 Expedition and Navigator vehicles built before 12/22/2006 may exhibit concerns with the Instrument Cluster (IC). The outside air temp reads 140 F (60 C), message center switches unresponsive/text blank or scrambled, compass display is inoperative, washer fluid level light is on.
ACTION:
Follow the Service Procedure steps to correct the condition.
NOTE: DO NOT REPLACE IC ASSEMBLY UNTIL COMPLETE DIAGNOSIS HAS BEEN PERFORMED.
SERVICE PROCEDURE
Check the build date code of the IC. The date code is displayed in the message center during "engineering test mode".
Engineering Test Mode:
Ignition in "OFF" position.
Cluster type.
For Base Clusters (without message center cluster): depress the reset stem on the cluster while turning the ignition switch to the "ON" position.
Message Center Clusters: depress the reset button in the vehicle while turning the ignition switch to the "ON" position.
Continue to hold down the reset stem/button for 5 seconds until the cluster message center displays "engineering test mode".
Press/cycle reset stem/button until the message center displays "manufacture" and the date of manufacture (MM-DD-YYYY).
If the date is after 12/22/2006, this TSB does not apply and proceed with normal diagnostics found in Workshop Manual (WSM), Sections 413-01 and 413-08.
Turn the vehicle ignition to the "OFF" position to exit the "engineering test mode".
Outside Air Temperature (OAT) Diagnostics
NOTE: THIS PROCEDURE IS FOR VEHICLES WITHOUT (ELECTRONIC AUTOMATIC TEMPERATURE CONTROL) EATC.
Run vehicle for 5 minutes.
Verify the OAT reads 140 F (60 C) in the Message Center.
Disconnect the OAT sensor.
Does the Message Center still read 140 F (60 C)?
Yes - proceed to Step 4.
No - follow WSM, Section 413-08.
Disconnect battery.
Disconnect IC.
Measure the resistance between pins 1 and 2 on Connector C132.
Resistance less than 1 Meg-Ohms - Repair shorted circuits.
Resistance greater than 1 Meg-Ohms - Proceed to Step 8.
Reconnect IC and OAT sensor.
Reconnect battery, to verify IC connection. If Message Center still reads 140 F (60 C), replace IC.
Message Center (MC) Switch, Diagnostics:
Refer to WSM, Section 413-08 Pinpoint Test B: The Message Center Switch Does Not Operate Correctly
Low Washer Fluid Level Light On, Diagnostics
Verify low washer fluid level light is on and washer bottle is full.
Verify washer fluid level switch is fully seated in the bottle. Is light still on?
No - repair is complete.
Yes - proceed to Step 3.
Disconnect the washer fluid level switch. Does the light go out after one minute?
Yes - proceed with normal WSM, Section 413-01 Diagnostics.
No - proceed to Step 4.
Disconnect battery.
Disconnect IC.
Measure the resistance on Pins 1 and 2 of Connector C138. Is the resistance less than 1 Meg-Ohms?
Yes - repair shorted wires.
No - proceed to step 7.
Reconnect the washer fluid level switch, IC and then battery to verify IC connections. If light is still on, replace the IC.
No Compass Display Diagnostics
Refer to WSM Section 413-08 Pinpoint Test C: The Compass Is Inoperative.
Message Center Display Blank/Text Scrambled, Diagnostics
Refer to WSM Section 413-08 Symptom Chart
WARRANTY STATUS:
Eligible Under Provisions Of New Vehicle Limited Warranty Coverage And Emissions Warranty Coverage
IMPORTANT: Warranty coverage limits/policies are not altered by a TSB. Warranty coverage limits are determined by the identified causal part.
OPERATION DESCRIPTION TIME
MT070704 Use SLTS Operations If Available; Claim Additional Diagnosis Or Labor Performed As Actual Time. Actual Time
DEALER CODING
BASIC PART NO. CONDITION CODE
10849 42
Old 09-08-2009, 06:25 PM
Sorry about posting in the wrong forum, my expedition is a 2000 Eddie Bauer. The trouble turned out to be a intermittent alternator problem. Everything back to normal now.
Old 09-09-2009, 06:51 AM
chuck s chuck s is offline
chuck s is starting off with a positive reputation.
My dash is fine (01-03-2007) but the "engineering" area of the display had some neat information on it such as a digital speedo.
Any other secret key presses on the panel?
I also just "discovered" the total mileage is displayed just pressing Reset with the ignition OFF.
-- Chuck
Old 09-15-2009, 03:05 PM
Just took it in to the dealer for repair. I hope they can find a code or duplicate it. Service tech says it is probably in the a/c control module. We'll see and I'll post results.
Old 09-15-2009, 03:28 PM
berry1234's Avatar
-- Chuck
How did you get it to display the digital speedo?
Old 09-15-2009, 06:23 PM
Follow the instructions in the Engineering Test Mode a few messages previously and just keep boinking thru the display until vehicle speed comes up. First one is MPH, second one is KPH. Pretty sure engine RPM is there as well as several other displays.
Only hassle is this mode has to be selected during startup and you don't get the regular display back until you shut down.
This is for "message center" equipped vehicles for sure.
Still wondering if there are other modes.
-- Chuck
Old 09-16-2009, 12:41 PM
berry1234's Avatar
Nice, I will check it out.
Old 09-16-2009, 04:30 PM
berry1234's Avatar
The engineering mode is pretty cool. Coolant temps, mph, RPM, real time fuel level, etc . I wish it had transmission temperature.
Old 09-17-2009, 03:36 AM
IQ9 IQ9 is offline
IQ9 is starting off with a positive reputation.
That is one cool feature..it is too bad we can only have it one way or the other....anyone trying to hack this so we have both?
Old 09-17-2009, 07:15 AM
Roger on transmission temperature! Would have saved me a couple hundred dollars.
-- Chuck
Old 09-17-2009, 11:30 AM
berry1234's Avatar
I still like the scan gauge. Too bad it's so expensive.
Another Dome light issue (dead Batt) Rickey Joe 1999 to 2016 Super Duty 0 06-30-2014 10:41 PM
Something Electrical?? Polkster 1999 - 2003 7.3L Power Stroke Diesel 12 06-26-2014 09:57 PM
84 f250 start problem Natcox012 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 8 06-20-2014 01:25 PM
7.3 Dead Dead 510galaxy 1994.5 - 1997 7.3L Power Stroke Diesel 7 02-17-2014 01:31 AM
2008 6.4L with codes, high idle & dead pedal. Merculous 6.4L Power Stroke Diesel 17 11-01-2013 11:02 AM
Tags
2008, 250, bauer, center, cluster, dash, eddie, engineering, ford, instrument, lights, message, mode, test, without
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
