Overheating 97 F150 - Ford Truck Enthusiasts Forums
Overheating 97 F150
Old 08-19-2009, 11:01 PM
riverbottom riverbottom is offline
riverbottom is starting off with a positive reputation.
Overheating 97 F150
I have a 97 F150 4x4, 4.6l V8. It only overheats on a cold start. The temp gage goes to hot and the fail safe light comes on but after about a minute the gage goes back to normal and the light goes out. My cap does pop and I lose a little coolant from the res. bottle. I have changed the t-stat, water pump, radiator hoses, pressure cap, temp sending unit, cyclinder head temp sensor, and have flushed the radiator. Also I have noticed that my heater will blow cool air until the temp gage goes to hot and starts to return to normal then my heater will start blowing warm air. Could my problem possibly be my heater core or heater hoses.
Old 08-19-2009, 11:24 PM
steve(ill)'s Avatar
steve(ill) steve(ill) is offline
steve(ill) has a great reputation on FTE.steve(ill) has a great reputation on FTE.steve(ill) has a great reputation on FTE.steve(ill) has a great reputation on FTE.steve(ill) has a great reputation on FTE.
i had a similar problem. found the thermostat was sticking. also i found out if i filled the antirfeeze tank to the full mark of an inch overfull, that expansion would make the tank go over pressure and cap leak. i now try to keep the level slightly under the cold full mark. have had much less problems. NO problems for first 3 years, no for some reason i have the high temp for 30 seconds then drops back to normal. New thermostat and slightly lower level has helped quite a bit.
Old 08-20-2009, 06:59 AM
torkum's Avatar
torkum torkum is offline
torkum is gaining momentum as a positive member of FTE.
Take the hoses off going into the heater core and try to flush it out. If it won't flush you will have to replace it.
Old 08-20-2009, 06:36 PM
galaxie641 galaxie641 is offline
galaxie641 has a very good reputation on FTE.galaxie641 has a very good reputation on FTE.galaxie641 has a very good reputation on FTE.galaxie641 has a very good reputation on FTE.
I'd say if you are lucky there is an air bubble in the heater core, either I'd look at it first.
Old 08-20-2009, 07:34 PM
n5926g's Avatar
n5926g n5926g is offline
n5926g is starting off with a positive reputation.
Quote:
I would re-replace the thermostat,and NOT one from Autozone,or the like. Go to NAPA or some reputable parts house.l
Old 08-20-2009, 10:25 PM
Overheating 97 F150
Quote:
Removed the heater core hoses and flushed them with water, also did the core. No apparent blockage.
Heat got cold temp gauge showed cold then overheated scrobbie 1997 - 2003 F150 3 12-10-2016 03:37 PM
heater blows cold air JP Hobbit 1997 - 2003 F150 5 10-10-2012 08:27 AM
trying to keep her cool joshofalltrades Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 23 05-15-2012 11:11 PM
Engine Temperature Fluctuations - not Thermostat 38Chevy454 Modular V8 (4.6L, 5.4L) 8 01-18-2011 12:08 PM
Thermostat on a 460 RabidJade 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 1 11-08-2003 11:24 PM
Tags
03, 2000, 54l, 72, 97, f150, f250, heating, hot, location, overheating, problems, replacing, sensor, temperature, thermostat
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
