Location of outside ambient temperature sensor .. - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 08-19-2009, 10:39 PM
98SurplusExpy 98SurplusExpy is offline
98SurplusExpy is gaining momentum as a positive member of FTE.
Putting a front end back together that I didnt take apart ... could someone take a pic or post a good description of where the outside ambient temperature sensor is located behind the grill on a 2005-2007 model?
I "think" its clipped somewhere on the LH side of the header panel .. but not sure exactly where.
Old 08-20-2009, 07:59 AM
rtazz17's Avatar
rtazz17 rtazz17 is offline
rtazz17 has a good reputation on FTE.rtazz17 has a good reputation on FTE.rtazz17 has a good reputation on FTE.
on my o2 its located right next to the radiator on drivers side.You can see it looking through the grill.May be different on your year though.
Old 08-20-2009, 11:18 AM
bpounds's Avatar
bpounds bpounds is online now
2 bit Californian
bpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputation
Here it is on mine. It was an add-on, but I do believe this is the correct location.
Old 08-20-2009, 11:39 AM
Is that on the hard-plastic grill reinforcement panel or the flexable rubber air deflector?
(thanks for the pic by the way!)
Old 08-20-2009, 11:45 AM
bpounds's Avatar
2 bit Californian
Not sure of the terminology, but it is hard plastic.
Old 12-13-2016, 06:46 PM
BobbyJPhotos BobbyJPhotos is offline
BobbyJPhotos is starting off with a positive reputation.
Anyone know where it is on a 2012 xl f250
Old 12-13-2016, 08:55 PM
azking_Ranch's Avatar
azking_Ranch azking_Ranch is offline
azking_Ranch has a very good reputation on FTE.azking_Ranch has a very good reputation on FTE.azking_Ranch has a very good reputation on FTE.
2011 and up its located in passengers mirror
Old 12-14-2016, 03:13 AM
That's what im told, I bought the replacement and I pop the little tap on the bottom of the mirror and I don't see the sensor in there....I can't seem to find a video how to anywhere on how to replace it....have any ideals of a help file or how to file/video?
Ambient Temp Sensor Replacement BobbyJPhotos 1999 to 2016 Super Duty 1 12-15-2016 03:51 AM
AC Problems, outside temp reads -40 kingrl2 2009 - 2014 F150 9 08-07-2016 11:33 AM
What does the ambient air temperature sensor do? El Campo Cooling, Heating, Ventilation & A/C 1 06-26-2016 01:31 PM
Ambient Air Temperature Reads 0c mcanik 2015+ F150 2 03-30-2016 05:38 PM
Ambient Air temp sensor 2000 e250 tjosephb 1968-2013 Full Size Vans 6 03-28-2016 11:15 AM
Tags
2009, 60, ambient, exterior, f150, f250, ford, found, location, ranger, rangertemp, sensor, specifications, temp, temperature, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
