Go Back   Ford Truck Enthusiasts Forums > Small Chassis Trucks > Escape and Escape Hybrid
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 08-19-2009, 07:24 AM
m350 m350 is offline
m350 is starting off with a positive reputation.
Is the New 2010 Escape towable ?
My sister and hubby just purchased a 2010 Escape, V-6,,,nice looking lil rig,,,he mentioned the dealer said it was towable behind a motorhome (they want a motorhome) I just recently heard that the Escapes were having tranny troubles from being towed ?,,,any ideas on this would be appreiciated,,,thanks,,,,,Mark
__________________
06' F-350 XLT SC, S-Bed, 6.0, Auto, man-hubs
04' Explorer NBX, 4.6, auto, 3:73 LS
68' Torino, 289, 4 gear
  #2 (permalink)
Old 08-19-2009, 09:48 AM
wptski wptski is offline
wptski is starting off with a positive reputation.
Quote:
There is a problem with flat towing. You should rear this thread from another forum: http://www.ford-forums.com/ford-esca...n-failure.html.
__________________
Bill
09 Ford Escape Limited, 3.0L, 4WD, AdvanceTrac
  #3 (permalink)
Old 08-19-2009, 10:20 AM
YoGeorge YoGeorge is offline
YoGeorge has a good reputation on FTE. YoGeorge has a good reputation on FTE.
Quote:
I have also read other accounts of problem towing an Escape and would not do so at this point, with the possible exception of a 2WD Escape with a stick shift trans.
Although it looks like Ford is replacing transmissions (and sometimes more than once) for owners who tow, I would not want to go there...
If their Escape is 2WD, I'd go with a front wheel dolly...
Good luck,
George
  #4 (permalink)
Old 08-19-2009, 12:04 PM
Good luck,
George
I don't think that anybody that has a transmission replaced after flat towing has tried it again using the revized lower ATF level yet.
What gets me that even Ford Techs have overfilled the transmissions!!
__________________
Bill
  #5 (permalink)
Old 08-19-2009, 12:29 PM
Based on prior experience (and being something of a skeptic and pessimist by nature), I am thinking that if there are problems towing with the trans overfilled, that running a pint less fluid (or whatever) is not going to solve the problem for serious long distance towing.
I hope I'm wrong...
George
  #6 (permalink)
Old 08-19-2009, 02:33 PM
I hope I'm wrong...
George
That's the Ford solution right now!
__________________
Bill
  #7 (permalink)
Old 08-21-2009, 05:06 AM
Opps,,my mistake,,I just found out it is a 2009 Escape they just purchased !
__________________
  #8 (permalink)
Old 08-21-2009, 10:46 AM
More than likely the 2010 has the same towing issue as the 2009.
__________________
Bill
  #9 (permalink)
Old 10-19-2009, 03:07 PM
jbescape jbescape is offline
jbescape is starting off with a positive reputation.
I own a automatic 2009 Escape and we purchased it to be our flat tow vehicle behind our RV. We purchased the Escape on June 3rd, 2009. So far we have placed the 6F35 transmission 2 times at Ford's expense. We followed all of the procedures for flat towing to the absolute "T". The low trans fluid between the min mark and the 1st hole did not make a difference. We will not tow this vehicle again. The Hybrids have a belt driven transmission and do not have this problem I have been told. We really like the vehicle but we will not be inconvenienced again by flat towing it.
Dismayed Owner, JB
  #10 (permalink)
Old 10-19-2009, 11:31 PM
Nitramjr's Avatar
Nitramjr Nitramjr is offline
Exiled from the club.
Nitramjr is a splendid one to behold Nitramjr is a splendid one to behold Nitramjr is a splendid one to behold Nitramjr is a splendid one to behold Nitramjr is a splendid one to behold Nitramjr is a splendid one to behold Nitramjr is a splendid one to behold
Quote:
It isn't a belt but a planetary drive system with three inputs - the gas motor and two electric motor/generator sets. IIRC the 4WD version of the hybrid has to be flat-towed only.
__________________
Ray
'97 F250 XL, 5.8L, '05 Escape Hybrid, '06 Escape Hybrid
  #11 (permalink)
Old 10-27-2009, 02:16 PM
patfrompagosa patfrompagosa is offline
patfrompagosa is starting off with a positive reputation.
I just had mine towed to the dealer
Like other RVers, I bought my 2009 Escape AWD (in Feb)specifically because it was 4 flat towable. I needed a snow vehicle and I needed a towable and I preferred a Ford behind my Ford motorhome.
I towed twice at 500 miles each and drove it in between. I had my 7500 mile service and towed twice more at 500 miles each. I ran it between gears as newly recommended. I've driven it a lot since (now at 11,200)
This morning I noticed an oil drop on the drive and looked under the hood. The tranny fill tube looked oily/dusty. I checked the level and it was off the stick low. So, I called the dealer and had it towed in.
A weird thing: when I pulled the tranny dipstick, there was a 1/2" x 1/2" x 1/8" (rough dimensions) of off-white semi-rigid plastic foam/sponge wrapped around the stick. I saved part of it, and sent the rest to the service tech (with the vehicle).
I really like the Escape, it gets me almost 30 mpg on a trip, has nice space, and handles very well. It is supposed to snow tonight, so I am going to miss it. But, at this moment I sure am glad I still have my 1999 Saturn wagon.
Tags
09 , 2009 , 2010 , dinghy , escape , flat , ford , forum , forums , luck , problems , tow , towing , transmission , user
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
