5.8L timing set number?
Old 08-19-2009, 02:45 AM
rockcrawler_101's Avatar
rockcrawler_101
rockcrawler_101 is offline
Ihave in my jeep a 91 ford bronco 5.8L, and i went to time it but the manual doesnt say what to time it too. I set it to 0 for now. But does anyone know where it should be set to? Im having problems with the starter acting like its low on battery when it gets warm. When i time it i pull the jumper thing by the distribitur. Am im doing it wrong?
Old 08-19-2009, 02:48 AM
smsperformance's Avatar
smsperformance
smsperformance is offline
you need to remove the spout connector and time it to 10 degrees BTDC....
Old 08-19-2009, 10:22 AM
xpl0sive's Avatar
xpl0sive
xpl0sive is offline
is the timing the same for having a cam? i've got a crane in mine, what should i time mine to?
Old 08-19-2009, 10:43 AM
lew52's Avatar
lew52
lew52 is offline
Will be the same 10 deg before with spout out .... Lew
Old 08-16-2013, 05:36 PM
muddbogger's Avatar
muddbogger
muddbogger is offline
Timing
I have a 1986 ford bronco with a 5.8 l in it i replaced the timing gears and timing chain in it i timed it and got it all put back to gether it started right up but when it warms up the oil pressure drops and it starts to sputter and try to die i have to hold my foot on the gas to get it to stay running. well i noticed my thermostat was leaking so i went to replace the gasket on the thermostat in order to get the last bolt off i had to remove the distributer i got the new gasket on and put the distributer back in and got it all back to gether and now it wont start at all what am i doing wrong some one please help i have been working on this damn truck for over a week now and i am about to give up on it
dionysius
11-20-2016 11:08 PM
TLI
02-11-2010 08:08 PM
knorkus
02-24-2008 10:55 PM
mako171
1978 - 1996 Big Bronco
18
12-20-2007 09:17 AM
Corey872
13
12-12-2003 02:44 PM
Quick Reply: 5.8L timing set number?
