Go Back   Ford Truck Enthusiasts Forums > Diesel > 2003 - 2007 6.0L Power Stroke Diesel
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
2003 - 2007 6.0L Power Stroke Diesel SPONSORED BY:
Is F-150 Still King?
  #136 (permalink)
Old 11-01-2009, 10:16 PM
tex25025's Avatar
tex25025 tex25025 is offline
tex25025 has a great reputation on FTE. tex25025 has a great reputation on FTE. tex25025 has a great reputation on FTE. tex25025 has a great reputation on FTE. tex25025 has a great reputation on FTE.
Quote:
Originally Posted by 88stang1 View Post
Yes it is and there will be some blending but as Chris Gabe has posted that it would make any oil better by adding Blue Diamond to it also if there is not much difference from my last OA after adding close to 16L of BD then it the same as any other oil.
That's true, however, think of it this way. Let's suppose that this BD oil is good, that there is enough improvement that it would warrant the extra cost(just enough of improvement that it would warrant the extra cost, not to the degree that LS is hocking it), if you are blending or cutting it with an inferior oil, that could drag down the result to where it would show on an analysis barely an improvement or no improvement at all. Or atleast a "negative" result that would keep people from spending the extra scratch for it, when that isn't the case if there wasn't a blending of the oil.
Now, if it's as good as they are hocking it, then my nit-picking is moot. It's just as someone that has done research, I just really am anal about "loose ends" like this.
There are also other variables here as analysis can vary between person to person to where gains seen by BD might vary as well, but since this is probably(as SteveBricks said) the only thing that we are going to have as it relates to the 6.0, I guess I'm just going to have to pucker up and roll with it til there is more to come in.
__________________
'06 6.0L Turbo Diesel King Ranch DRW 4.30 Gears
Spartan Stage 1 Towing Injectors
Spartan 64mm Non-VGT Turbo
Fluidampner
Headstuds
Beta Spartan Phalanx
Fuel Regulated Return
FASS 150/180
Suncoast Heavy Duty Torqshift Rebuild
5" Straight-Piped MBRP Exhaust
Tranny, EGT, Boost, and Fuel PSI C2 Gauges
Water Temp, Oil PSI, Volts Antique Beige Gauges
  #137 (permalink)
Old 11-14-2009, 08:39 AM
tex25025's Avatar
I'm going to be the one that brings this bad boy back to the top just because I want to see the results of the oil analysis. Surely it should be done by now. 88stang1 you have it back yet and any pictures or scans for us to see the results?
__________________
Fluidampner
Headstuds
FASS 150/180
  #138 (permalink)
Old 11-14-2009, 04:14 PM
88stang1's Avatar
88stang1 88stang1 is offline
88stang1 is starting off with a positive reputation.
Quote:
Yes I do have the results of the oil analysis it came back as normal no corrective action required the vis@100c 13.42 not sure how to upload my scan if someone could let me know then I will put it up.
  #139 (permalink)
Old 11-14-2009, 05:14 PM
tex25025's Avatar
Normal, but not better with the addition of the Blue Diamond?
__________________
Fluidampner
Headstuds
FASS 150/180
  #140 (permalink)
Old 11-14-2009, 05:28 PM
88stang1's Avatar
No, it was better then Rotella the analysis for Rotella came back as abnormal and required oil change if not already done I am going to wait until I hit 8000miles and send another sample out only have 1200miles to go.
  #141 (permalink)
Old 11-14-2009, 05:34 PM
SteveBricks's Avatar
SteveBricks SteveBricks is online now
SoCal Chapter LDR
2006 Ford F-250
My Garage
SteveBricks has a superb reputation SteveBricks has a superb reputation SteveBricks has a superb reputation SteveBricks has a superb reputation SteveBricks has a superb reputation SteveBricks has a superb reputation SteveBricks has a superb reputation SteveBricks has a superb reputation SteveBricks has a superb reputation SteveBricks has a superb reputation SteveBricks has a superb reputation
If you have the scan saved to your desktop go ahead and hit the 'post reply' button, then scroll down to 'manage attachments' under 'additional options'.
Click on manage attachments then browse you computer for the scan and upload it. That will put it in the post.
__________________
NHRDA #4698
SoCal FTE
Join our Chapter *HERE*
9/21/54 - 9/25/09
  #142 (permalink)
Old 11-14-2009, 05:50 PM
88stang1's Avatar
It says that I cannot post probably bcause I do not have enough post not sure?
  #143 (permalink)
Old 11-14-2009, 05:54 PM
SoCal Chapter LDR
2006 Ford F-250
My Garage
You could create a Photobucket account: Register for free at Photobucket.com
It's free, and it makes it real easy to post pics.
If you need a hand setting it up send me a private message and I'll help you out.
__________________
NHRDA #4698
SoCal FTE
9/21/54 - 9/25/09
  #144 (permalink)
Old 11-14-2009, 06:06 PM
88stang1's Avatar
I have it posted now how do people find it
  #145 (permalink)
Old 11-14-2009, 06:29 PM
88stang1's Avatar
I beleive I got it let me know
  #146 (permalink)
Old 11-14-2009, 06:36 PM
88stang1's Avatar
I am off to work any question I will answer tomorrow
  #147 (permalink)
Old 11-15-2009, 12:26 PM
88stang1's Avatar
Thumbs up
Does anyone have any thought on the results what about the sceptics.
Also as a footnote this was the first time using Blue Diamond so there is some blending and the results are still positive compare to Rotella which disintegrated with same amount of miles.
Blue Diamond also had more miles of towing on it round trip to the east coast of Canada approx. 3000miles Rotella had about 500 miles of towing.
  #148 (permalink)
Old 11-15-2009, 12:37 PM
SoCal Chapter LDR
2006 Ford F-250
My Garage
Part of the low viscosity on the Rotella sample was probably due to fuel dilution.
I'm not familiar with the format of this oil analysis, but if I'm reading it right isn't it showing an increase in wear metals, except for iron?
__________________
NHRDA #4698
SoCal FTE
9/21/54 - 9/25/09
  #149 (permalink)
Old 11-15-2009, 01:09 PM
88stang1's Avatar
I would agree to that but as you may know that the shearing of the oil is the big culprit.
  #150 (permalink)
Old 11-15-2009, 01:10 PM
88stang1's Avatar
I will upload the back of the sheet which will give some explanations.
Tags
2005 , 40 , 5w , 60 , 73 , change , f350 , ford , loss , miles , oil , power , rotella , strok , time , truck , viscosity
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
