oil plug broken please help! - Ford Truck Enthusiasts Forums
2007 - 2014 Expedition & Navigator 2007, 2008, 2009, 2010, 2011, 2012, 2013 and 2014 Ford Expedition and Lincoln Navigator
Old 08-18-2009, 11:35 PM
jdm5630 jdm5630 is offline
jdm5630 is starting off with a positive reputation.
Well i was going to change the oil myself and im guessing the thread on the pan or the bolt are worn because the bolt spins in both directions but it wont come out. What can i do to get it out?
Old 08-18-2009, 11:49 PM
berry1234's Avatar
berry1234 berry1234 is offline
berry1234 is gaining momentum as a positive member of FTE.
How many miles do you have? If under warranty I would take it in and have them fix it. It's pretty hard to ruin a drain plug. The factory may have cross threaded the bolt on.
Old 08-18-2009, 11:52 PM
well i just bought it, i am going to take it to the dealership tommorow and see if they can fix it
its out of warranty
Old 08-19-2009, 08:18 AM
gddyup's Avatar
gddyup gddyup is offline
gddyup is gaining momentum as a positive member of FTE.gddyup is gaining momentum as a positive member of FTE.
The pan threads are most likely stripped. The pan usually strips before the plug does. To get it out you can use a screwdriver or something flat like that and "wedge" it under the plug as you turn it. That will usually help get it out. But, if the pan is stripped it depends on how bad it is as to whether or not you'll get a plug back into it. You can find pan taps that *might* be able to clean the threads up, but again it depends on how bad it is. You can also by replacement self-tapping plugs that will create their own threads in a damaged pan but they are pretty "backyard mechanic" and don't always work. I've seen pans "repaired" both ways and people have gotten along fine but either of those fixes would be my last choice solution. The best choice would be a new pan and plug but moeny factors will weigh heavily on that decision.
Old 08-19-2009, 11:27 AM
berry1234's Avatar
The pan and gasket online can be had for around $120 for both. Best bet would be buy these along with a new drain plug if the dealer you bought it from won't help you out.
96' 2.3 head bolts.... Ernest Webster Ranger & B-Series 0 12-21-2014 12:00 PM
oil pan bolt size Paulsf350sdcc 6.0L Power Stroke Diesel 11 06-09-2014 05:03 PM
Oil cooler removal Podaso 1997 - 2003 F150 3 03-15-2011 01:28 PM
oil pan removal mamabear13 1973 - 1979 F-100 & Larger F-Series Trucks 21 07-23-2008 01:25 AM
bolts on ford 302 oil pan kevs66coupe Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 2 09-02-2004 11:11 AM
Tags
150, 2006, bolt, broke, broken, cross, expedition, ford, oil, plug, thread, threaded, treaded, wont, worn
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
